TDI Used Oil Lab Analyses Results & Discussions
CleverUserName
NorCal
Here's a little info from Blackstone regarding soot in oil and testing for it:
https://www.blackstone-labs.com/soot-how-much-is-too-much/
And here is a compilation of iron wear numbers from various oils in tdi's. Note the Rotella T6 is among the top performers. Yeah, some might say formulas change blah, blah, blah- I would argue that the T6 formulation has only gotten better over time.
http://forums.tdiclub.com/Blackstone oil wear test
This article provides much more information about soot control and it's effect in Engine oils if you care to read it. https://www.machinerylubrication.com/Read/51/soot-oil-engine
TLDR - An engine oil with adequate dispersants in the formula does not readily thicken until soot gets over 4%. With additional dispersants, the soot load can be increased to over 7% before thickening takes place: Viscosity Vs. Soot Level
Most people who test different oils methodically don't use Blackstone because of their dubious testing methodology, questionable comments and the reasons we've already discussed.
I've seen Amsoil and Redline stomp on T6 in comparative tests on the same vehicle. Over and over again.
As I already said, numerous times, all these recent oil analysis that we have seen with T6 in an ALH that show premature thickening have LOW INSOLUABLES (Soot) as measured by blackstone.
turbobrick240
maine
Barring a conspiracy by Blackstone to make Amsoil look worse than it is, I'd say the only thing they're stomping in tdi usage is the owners wallet. The point of that exercise by Blackstone was to show that oils of appropriate weight & specification provide similar results, and people worry far too much about which oils are "best". Any 5w40 that meets CJ-4 or CK-4 certs is going to work great in the pre dpf tdi's.
jerryfreak
Nor Cal
02 Jetta GLS sedan @295K, 99 Jetta sedan 275k,. 2015 tdi sedan, 105k
i hate this MK7 oil change vs my MK4. can i cheat and do the filter every other change if i drop the OCI from 10K to 7.5 (using an extractor on the times i dont drop the pan). i dont mind lowering OCI
tdiman
bridgeport wv
jetta 2015 sel grey / black interior
Quite possibly the filters were designed 30,000 mile intervals
tdiman
bridgeport wv
Interesting read I Found this on the TDI board somewhere
The ORIGINAL factory APPROVED oil change interval is 30,000 miles! YES 30,000 MILES!!
Did you comprehend that?
THE ORGINAL OIL CHANGE INTERVAL APPROVAL IS 30,000 MILES!!!
Now that I have that off my chest,
VW reduced the interval from 30,000 miles to 10,000 miles in the US market...any guesses why?
Because people like you either:
1) Can't read the owners manual
2) Don't trust the car makers
3) Can't follow directions
4) Fail to adhere to the service indicator in the car
VW does NOT want oil change intervals of less than 10,000 miles due to how the oils function in the engine, shorter intervals INCREASE WEAR, Don't argue with me about it, if you take the time to track wear rates during an oil change at 250 mile intervals you can plot the reduction and stabilization of the wear rates out beyond 25,000 miles!
Think of oil as having 2 types of wear reducing additives, the first provides protection by/thru detergancy (cleansing of internal surfaces), dispersing soot, neutralizing acids (not an issue now with ULSD), and several other types as well. These additives are generally very specific to diesel engines and must pass specific tests in VW Diesel engines.
The next type of additive is a wear additive. These protect the engine where the thickness of oil may be too thin to prevent metal to metal contact. Other additves in this type range also provide protection to the cam and lifters, engine bearings, piston wrist pins etc.
Now pay attention, the 2nd group of additives account for less than 3% of the total volume of the oil. These additives also account for 90% of the engines oil protection! These additives require heat and pressure to bond with the critical wear surfaces, but due to the low percentage of additive in the oil they require time to fully place on those surfaces by the pressures of the component they are protecting. Example, an engine at operating temperature at the point where the cam presses on the lifter generates in excess of 90,000 psi, that pressure and the heat of the engine causes the 3% portion of the 1 micron thick oil film to form a crust or sacrifical layer at the point of contact. Since only 3% of the oil contains the wear additives, it requires hundreds of thousands of passes to generate a sufficient film to stop the wear at this specific point in the engine.
Everybody is quick to make the arguement that the old oil had these additives so they are already in place, right? not quite!
Remember the first type of additive? In that 1st group you had "detergents" that cleanse the inside of the motor. These cleansers are used up very rapidly after an oil change since they attack the remaining oil that was left after the oil change. These cleansers if you will also reduce the effectiveness of the high pressure wear additives...See where this is going?
Before explaining further, after that initial period the dispersants in the oil work to prevent the adhering of the particles in the oil to any of the internal surfaces. These additives are often unique to diesel engines are also the reason why the oil looks so black so quickly, they are doing their job by preventing the soot from building up in any one place instead they are dispersed in the oil evenly throughout the oil sump which prevents sludging and other contamination related issues.
Back to the detergents and the high pressure additives, the layers of high pressure additives leftover are not being replenished after the oil change due to the cleaning process that is going on with the new oil to neutralize the remaining acids, and other contaminants in the engine. As the cleaners in the oil are used up in the first 500-1000 miles, the wear additives are able to re-generate a protective layer in the engine that stops the wear at that location.
You break down the oils life cycle like this:
Phase 1: Detergants attack the internals removing accumlated contaminants, neutralize acids and force those into suspenstion in the oil. This period of time lasts between 500-1000 miles
Phase 2: During the first 1000 miles the oils viscosity provides the majority of the wear protection by virtue of the film it creates on the surfaces. This phase generates relatively high wear rates but due to the short duration this is accepted due to the removal of contaminants that could result in long term damage to the motor. Wear rates in the period of time are generally speaking 5-10ppm per 1000 miles.
Phase 3: Detergents are now used up and the oil additives are forming their protective layers in the "extreme pressure" regions of the motor. Now the oil additives are working in conjunction with the oil film and the wear rates drop from 10ppm per 1000 miles to around 1-2ppm per 1000 miles.
Phase 4: Longterm peace! The oil is operating in a period of equilibrium, the wear additives are placed, Oil viscosity is in perfect range for the engine, Dispersants are continually working to prevent soot and other contaminants from accumulating on the surfaces and wear rates remain between 1-3ppm per 1000 miles.
Phase 5: Oil run out, the oil during this phase begins to increase in viscosity (or thin in some cases), Extreme pressure additives begin to lose effectiveness due to increased concentrations of wear particles (VW tests out to 8%, most oil changes never see in excess of 2% after 30,000 miles). This is when you begin to see a rise in the wear metal formation in the engine. Often wear metals during this phase rise to the 3-8ppm per 1000 mile range. Notice that the wear metals being generated are still LOWER than they were in the first 1000 miles?
When somebody says they are going to change the oil every 5000 miles or twice as often they are DOUBLING the number of detergent cycles and DOUBLING the number of cycles where the engine is running at it's highest wear rates!
PPM/Fe (generation of Fe in 1000 mile increments)
Short drain intervals
1K oil change
10ppm = 10ppm in 1000 miles = 10ppm/1000 miles
3K oil change
10+2+2 = 14ppm in 3000 miles = 4.6ppm/1000 miles
5K oil change
10+2+2+2+2: Change oil = 18ppm in 5000 miles = 3.6ppm/1000 miles
Long drain intervals
10K oil change
10+2+2+2+2+2+2+2+2+3 = 29 ppm in 10,000 miles = 2.9ppm/1000 miles
15K oil change
10+2+2+2+2+2+2+2+2+3+3+3+3+3+3 = 44ppm in 15,000 miles = 2.9 ppm/1000 miles
20K oil change
10+2+2+2+2+2+2+2+2+3+3+3+3+3+3+3+3+3+4+4 = 61ppm in 20,000 miles = 3.3ppm/1000 miles
When ppm of Fe per 1000 miles reaches 5-7ppm per 1000 miles you can consider the oil ready for a change...
The above is based on real world TDI oil samples.
I have personally used up to 25,000 mile oil drain intervals on my TDI and still never reached the 5-7ppm range! I changed it at that time due to soot and TBN depletion (high sulfur fuel at the time).
Anybody that tells you that short oil drain intervals are good for your motor don't know what they are talking about!
DB
DBW LLC
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
casioqv
California
2009 Touareg TDI
I change the Mobil 1 TDT oil every 15k in my '01 TDI, but everytime the Blackstone analysis suggests that the oil is well within spec, and there was no reason to change it so early. I still can't bring myself to actually go 30k.
James & Son
Maryhill, Ontario, Canada
2006 Jetta
TDIman,
If you analyse your theory, it has a lot of holes in it. The following makes a lot more sense.
HTHS(high temp/high shear)synthetic oil and a proper TBN for the service conditions and interval and dynamic viscosity starting with recommendations by the manufacture.
Hear is how VW explains it. Most people will find the last page hasn't changed the thinking much when it comes to service conditions but synthetic oil has allowed increased service intervals for most light duty vehicle applications.
I am not sure which service regime is best for me.
The choice or regime can be dependent on how the car is driven and the conditions of
use, It is impossible to state any hard and fast rules. However, if you are not sure,
Volkswagen recommends that your car be set to the factories default of the LongLife
regime. The service indicator will tell you when the first service is due. Your
Volkswagen Retailer or repairer will then discuss the best regime suitable for you to
adopt. To help you identify which regime may be best for you, please refer to the
following guidance.
LongLife Regime.
To obtain the most benefit from the LongLife service regime, the car should to be
generally driven in a style/condition of use listed below:
• Mainly longer distance journeys
• Limited number of cold starts, engine is kept at operating temperature over a
longer period of time.
• Daily mileage above approx. 25 miles.
• Constant speed.
• Vehicle used regularly.
Time/Distance Regime.
It your car is driven in a style if listed below, it may be more appropriate to opt for the
Time and Distance regime
• Extremely uneconomical driving style ie continual maximum acceleration ie. ‘foot to
floor’.
• Vehicle fully loaded.
• Mainly short journeys.
• Frequent cold starts.
• Frequent hill climbs.
• Frequent towing.
• City centre driving.
For further information concerning the servicing regimes, please consult your
Volkswagen Retailer or repairer for full details.
Please note
All mileage stated is an approximate guide as the service indicator system uses
kilometres as the distance measurement.
Last updated September 2007.
commedeschatons
dtw
2014 q5 tdi, 2012 golf tdi 6mt (bought back)
3.0 TDI w/ Malone Stg 2 and Rawtek downpipe. First column is whatever was in the car when i bought it.
turbobrick240
maine
Those wear numbers look fairly decent, but I wouldn't be happy with that viscosity loss. No way would I want to take what is now effectively a 20 weight oil out to 15k miles. I wonder if you're getting a strong biodiesel blend- that could explain the sodium and viscosity loss through fuel dilution.
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG
I'm not purposely getting higher bio-blend but it could be. I only fill up at 2 different BP stations here in Nebraska for the most part. I also do use Schaeffer's winter and summer fuel additives (switched from Howes) which also could be it, I'll have to look into that.
I hear ya on the dilution side (I kind of wonder how big of a deal just 1pt under recommended is), this next run will be the end of my experiments to find the sweet spot. If nothing else and I keep with 13k and be done with it. This was an over the winter run and I did more in town driving so less efficient and more regen cycles. With summer arriving and vacations, I think I'll pile on more miles, faster and more efficiently so it should be interesting to see what the dilution affect ends up doing on this next longer run.
At the end of the day, it's definitely better than the Castrol (that is what was in for the first UOA on the report after 20k of being broken in) and once I know what 15k looks like, I'll stop testing for a 30k miles and just drive, change and enjoy the ride. I absolutely love my MY15 GSW and plan to drive for a very very long time. Kind of what to buy another. :)
James & Son
2006 Jetta
I am glad to see you have 3 test reports with this oil. Note that your last report was better than this report on a wear per mile bases. I know you said it was winter and city driving and probably you are right. I would not go beyond 13000 under those conditions. As far as break in, Oil Hammer claims final iron and bearing break in at 60,000 miles. I would want to see all wear improve again before testing beyond.
As the moly disulfide( MO2) is used up it turns to MO3 which is abrasive from the scientific papers I have read. Just keep that in mind as you go forward.
James & Son
2006 Jetta
Regarding Scheaffer 8008
First of all it is a Mid saps oil. This is not 507 complient ash wise. I should have known this when I saw the amount of Modtc in the oil.
If you read the last paragraph of Go Faster's sticky
If you use an oil that doesn't meet VW 507.00 in a common-rail engine, there is a risk that the additive package in the oil will be incompatible with the (very expensive) emission control system - and it's not only the emission control system at risk. These engines deliberately squirt an extra shot of fuel into the cylinder on the exhaust stroke to heat up the catalytic converter in order to "regenerate". A portion of this fuel will end up on the cylinder walls, be scraped up by the piston rings, and end up in the crankcase, where it will dilute the engine oil. The engine oil must be designed to tolerate a certain amount of fuel dilution on these engines.
I think this answers why your viscosity is dropping and also why Scheaffer is saying, only meets these standards if used at manufactures recommended oil change intervals.
I have always questioned any benefit of using modtc in a diesel engine if any form of catalytic convertor is used as it is high temperature resistant and may end up coating the surface over time.
asgoodasdead
NJ
2011 Jettta Sportwagen TDI
1K oil change
3K oil change
5K oil change
10K oil change
15K oil change
20K oil change
DB
DBW LLC
do you think the 30k international vs 10k US interval has to do with the EGR valve?
Sent from my PH-1 using Tapatalk
TornadoRed
Saint Paul (ex-San Diego)
2003 Golf GL 5-spd, red; 2003 Golf GLS 5-spd, indigo blue; 2003 Jetta TDI wagon, Candy White (SOLD); 2003 Jetta TDI wagon, silver; 2003 Jetta TDI wagon, indigo blue
I think VE and PD engines everywhere had EGR valves.
Mrrogers1
Omaha NEEEBRASKA
Thanks for BOTH posts on this. I will test at 13k again but based on summer driving with more long distance driving and see how it looks. 13k may just be the wall and I'll roll over that magical 60k number during this next OCI as well. I may end up just sticking to the 10k OCI but I don't mind and like to be able to look at how the numbers shake out. :)
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
About a month ago I had my oil changed, but I forgot to send in the oil sample. It has been sitting in my garage for the last month.
Is it still a good sample to have tested or should I just recycle it and wait for the next?
Mrrogers1
Omaha NEEEBRASKA
I'd call the lab and ask. I can't see how the moving around of the contents, basically shaking up, wouldn't make it ready to test but the lab would know best.
Let us know what they say! :)
tdiman
bridgeport wv
TDIman,
following guidance.
LongLife Regime.
• Constant speed.
floor’.
• Frequent towing.
Please note
I average 2,000 a month high way driving sometimes a bit more and I have some town driving also and I always Idol 10 min before I leave I like my car to be at temp before I drive just me And after a 100 miles trip I will idol some before I turn off car my feelings before I started doing oil Analysis was I bet this oil can go double the mileage the dealer says 20,000 miles so from now on I will test at 20,000 to c what report says and decide at that point whether to run it at 30,000 or make my Standard oil change at 20,000
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
I suppose I really should have checked their website first. LOL.
In the FAQ There is a question that asks if an oil sample that has been sitting in the garage for 3 months would be OK. And they say it should be fine.
One very important lesson learned though....
Their website is www.blackstone-labs.com
NOT www.blackstonelabs.com
turbobrick240
maine
Lol. Says a lot about that demographic. Gotta get some Arson. Must have edged out Arsenic when they were brainstorming product names. :rolleyes:
tdiman
bridgeport wv
tdiman
bridgeport wv
I also sent a oil sample in at 300 miles to compare. This is my new 2015 Jetta sel first 10,000 miles no oil added I'll try another 10,000 this was 3 months of driving
CleverUserName
NorCal
New to me 2003 Jetta w/ 272K. More info about car here: http://forums.tdiclub.com/showthread.php?t=499768
Previous owner said it was Castrol Edge 5w40 505 oil. He was fueling up exclusively with this stuff they sell in the SF area which is B20 and Renewable Diesel blend. This hippy fuel is expensive at nearly $5 a gallon. He had about 3K on this fuel and I started filling up with D2 for 3K. I guess this is the reason the soot was so high. I usually see a soot value 1/2 from this UOA on Cali D2 or pure Renewable Diesel as fuel. He was also only averaging 32 MPGs while I'm at 44.3 with D2.
I refilled with M1 TDT 5w40, old CJ-4 formula w/ a bottle of LM Ceratec I had laying around. I am never impressed with VW 505 oil UOAs and think 505 oils are a compromise compared to real API Diesel truck oil like CJ-4 or CI-4+.
VegasGolf
N LasVegas
13 Golf tdi
A simple chip to your 06 will make it just as powerful and torquey as the 09, with better MPG and no car payments.:D
Great point,
My first TDI, but had many Golf’s & Rabbits.
Jumped back into Golf tdi for 11800. ( buy back re-sale )
22k miles. And no car payment.
Took me 52 years to get here now let’s see how Long i can keep this running.
benson4349
Eastern WA
2002 Jetta Wagon (ALH, MT)
Tonight's the first time I've done much reading on the forum about UOA, and I just have to say... this can't be coincidence... :D
JohnWilder
Breckenridge, TX
2003 Jetta 5 spd manual
My New Oil change schedule and procedure
You guys will think I'm nuts. I was always an oil change every 3,000 miles guy. How I've changed.
I now change oil once every 20,000 miles. Yes. That is right. I don't change the filter. I leave the dirty oil in the filter case and only drain what comes out without removing the filter.
Now. You probably think I'm nuts but I've thought it all out and here is my thinking:
I used to work for a diesel engine manufacturer. These engines were 1,000 hp per cylinder. They were big. They never changed the oil. They would take samples on a periodic schedule and add additives as the analysis dictated.
I remember reading oil analysis over time back here about 5 years ago. The upshot was they found no change in the viscosity or rate of wear all the way to 20,000 miles. So. . . they concluded one change every 10,000 miles was conservative. There was a note that the greatest amount of wear in any 2,000 mile increment was the first, when the oil was new.
That got me thinking. When I was a boy (late 1950s, early 60s) no car ever lasted 100,000 miles. You overhauled the engine before then. Yet diesel trucks would last 200,000 to 300,000 miles. I could never understand why. Now I have the answer. The soot that builds up in the oil acts as an extreme pressure and anti scuff additive. The soot is good. So I don't remove all the oil now when I change it. It is always sooty.
I've had a bad hobby of flying old airplanes. The old airplanes never had any oil filters. The later models now have oil filters. However the newer aircraft don't go any further before engine overhauls than the old ones.
I've removed the filter, drained it, cut it open, and spread it out. I've never found anything caught in the filter. There is nothing in the combustion process that is big enough to be caught in the filter.
The only other thing I do other than blocking the EGR is I add 1/4 oz. ATF per gallon of fuel when I get fuel. I've found that it increases cetane rating resulting in a smoother running engine.
I've just changed the oil yesterday. I recovered all but about one cup of oil after 20,000 miles. This car uses essentially no oil. It's amazing. It now has 186,000 miles on the odometer. Just passing along what I'm doing.
