wjdell
Calculated by dividing total wear metals by miles in thousands. The national average is 6.538 ppm total wear metals, less Mn and Ni. This is based on 51 ppm total / 7800 miles by Blackstone.
TDI Club Ave : 6.952 ppm. ~~~~~~ Club Ave. OCI : 9981 mi. 8/25/09
Average wear for API ---- 4.10 ppm TWM
Average wear for VAG --- 8.38 ppm TWM
For the top 24 users in each catagory shows that API oils are 26% lower in wear over VAG oils.
“used oil analysis” Database : Instructions
1. You must submit all information in the format shown at bottom.
Use your same post for every UOA, to save space, and to make it easier to read. If you post twice, you will not be counted till you delete the second post. So, every time you get a new UOA, go back to your original post and edit it. Or add the UOA you want tabulated to the top in the required format. Link to your full UOA's below your database entry. SunRG's UOA and discussion thread is there for you, http://forums.tdiclub.com/showthread.php?t=154548, use it. If you want to have a separate thread for all your UOA's, then post all your UOA's in ONE thread. This will save space and you can post a link to it in your personal UOA thread. This will show all your UOA's in one click. People can then see your trend and make sense of it
2. The minimum for tabulation into the database is 5000 miles, or 125 hours if you have a meter.
One hour is equivalent to 40 miles. We have users that average less than 25 mph. Its a honor system so you need not post your lab copy of UOA, again space. It need not be your last UOA, or your best UOA, but only the one at the very top will be included. Manganese and Nickel are optional for now.
3. There are no deductions for baseline but you may deduct for VOA on a batch.
If you need to bring something to attention, send me a private message. If you need to bring attention to another poster, send a message. In the end we should be able to form norms by engine code., and as well learn about oil performance. Just because you do not have a great UOA, please post it anyway. If we do not get a wide range of posters then the data will lack accuracy. Your information may be more important than the leaders posting the lower numbers. You may have more than one engine. If you would like to add a engine then put a number at the top. If I miss it then mail me and let me know. If you wish to remain anonymous you must send me a copy of the UOA, less name and address.
THIS MUST BE AT THE TOP OF YOUR POST. ALL, that's ALL other info goes below.
# 1 - 2 etc. (if you have more than one engine, only if neccessary)
Date:
Engine Code:
Miles/Hours oil:
Miles/unit:
Oil Type:
Fe Iron:
Cr Chromium:
Al Aluminum:
Cu Copper:
Pb Lead:
Sn Tin:
Ni Nickel:
Mn Manganese:
By-Pass: "yes or no"
Top off Oil:
- Odinsjetta 05/17/09 ALH Total MC3 1.667
- VATechTDI 04/23/09 ALH Rotella T CJ4 1.782
- aja8888 06/24/08 ALH Rotella T CI4+ 2.252
- Braga_Dub 03/26/08 ALH Elf DID 505.01 2.500
- Eb2143 06/01/09 ALH Mobil TDT CI4+ 2.579
- Revolutionary_mind 01/08/09 BEW Mobil TDT CI4+ 2.674
- phaser 08/27/08 BEW Elf LLX 504/507 2.716
- MikeB60 02/15/08 ALH Mobil TDT CI4+ 2.783
- truman 04/24/09 ALH Rotella T CI4+ 2.857
- Bob_Fout 07/19/09 ALH Amsoil DEO CJ4 2.947
- oEo 07/18/09 BEW Total MC3 3.036
- pruzink 04/27/08 BEW Elf DID 505.01 3.086
- Kalebenne 02/16/09 BHW Total MC3 3.144
- mchapek 08/30/09 ALH Rotella T CI4+ 3.186
- Dimitri16V 06/16/09 BEW Mobil TDT CI4+ 3.200
- truman 04/07/08 ALH Mobil TDT CI4+ 3.273
- aNUT 01/06/09 ALH Mobil TDT CI4+ 3.298
- Galactic Warrior 08/26/08 ALH Mobil TDT CI4+ 3.300
- Gmark 07/30/08 BEW Mobil D ESP CJ4 3.364
- tommyt 01/04/09 ALH Rotella T CJ4 3.374
- WHATSUPDOC 08/21/08 ALH Elf CRV 506.01 3.409
- fitski 02/11/08 BEW Elf DID 505.01 3.450
- WJDell 04/20/09 BRM Schaeffer S9000 CJ4 3.562
- volmaniac 02/07/08 ALH Mobil TDT CI4+ 3.754
- ANON # 43921 04/12/08 BEW Schaeffer S9000 CJ4 3.819
- AndyH 05/11/08 1Z Amsoil DEO CJ4 3.864
- Blue_Hen_TDI 10/16/08 1Z Mobil ESP 504/507 3.912
- N2carz 05/31/09 BRM Mobil TDT CJ4 4.016
- spuimatt 03/13/08 ALH Amsoil AME CI4+ 4.492
- Ski_in_ NC 08/11/08 ALH C Pro SLX II 505.01 4.731
- JohnB 06/01/07 ALH Esso XD3 CI4+ 4.800
- astrolumen 06/22/09 ALH Mobil ESP 504/507 4.824
- TedHurst 11/08/08 BRM C Pro SLX II 505.01 4.898
- AndyH 11/04/03 1Z Amsoil HDD CI4+ 4.899
- Redputter 11/04/08 ALH Castrol SynTec 5.100
- tdileadfoot 10/20/08 BRM Elf LLX 504/507 5.115
- Nellie 12/22/07 BEW Motul Specific 505.01 5.169
- Lekolite 05/17/09 ALH Elf LSX 5.192
- silverbox 10/21/08 ALH Mobil D ESP CJ4 5.206
- tommyt 08/28/08 ALH Rotella T CI4+ 5.306
- thermographer 02/29/08 BEW VW LL III 504/507 5.333
- icecap 07/30/08 BRM C Pro SLX II 505.01 5.400
- zanzabar 06/09/08 BEW VW LL III 504/507 5.577
- spiceredwagon 06/20/08 BEW Elf DID 505.01 5.592
- nutdriver 06/09/09 BRM Mobil ESP 504/507 5.806
- Almagne 06/22/08 BRM Elf LLX 504/507 6.258
- Matt65 08/03/09 BRM Total MC3 6.378
- AndyH 07/23/07 BRM Amsoil AFL 505.01 6.500
- Hutchman 05/01/09 BRM Elf LLX 504/507 6.553
- gern 03/28/08 ALH Elf DID 505.01 6.588
- cbass94 10/11/08 ALH Rotella T CI4+ 6.900
- milehighassassin 06/05/08 BEW Elf LLX 504/507 6.932
- EVO&TDI 03/10/08 BEW Amsoil AFL 505.01 6.947
- blkpas 08/27/08 BHW Elf CRV 506.01 7.600
- ANON # 20444855 04/07/08 BEW Mobil TDT CI4+ 7.750
- maktas 09/09/08 BHW VW LL III 504/507 7.778
- RichOxfordBlue 05/18/09 BRM Elf LSX 8.000
- Brock_fr_WI 01/28/08 ALH Elf CRV 506.01 8.087
- whitedog 01/11/09 BEW Castrol TXT 505.01 8.300
- Foobert 03/15/09 BEW Elf LSX 8.491
- cbass94 08/03/08 ALH Elf LLX 504/507 9.100
- TdiPd05 02/27/09 BEW Total INEO 507 9.604
- leicaman 11/20/07 BHW C Pro SLX II 505.01 9.800
- MarbleTDI 03/28/08 ALH Mobil ESP 504/507 9.928
- Low_Velocity 08/18/08 BRM Elf CRV 506.01 10.300
- deepseafortydog 07/19/08 ALH Amsoil AFL 505.01 10.434
- AndyH 07/23/06 BRM Motul Specific 505.01 10.543
- Abacus 08/05/08 1Z Rotella T CI4+ 11.276
- Mdfirefighter 05/22/09 BRM Elf LSX 12.503
- Diesel Addict 12/25/07 BEW Red Line CI4+ 12.815
- 04PDWagon 12/19/06 BEW Motul Specific 505.01 14.200
- dhdenney 09/15/08 BRM VW LL III 504/507 14.366
- Jetta09chicago 07/14/09 CBEA Factory 14.788
- mparker326 08/27/07 BHW Quakerstate 505.01 16.533
- sdeck 08/10/07 ALH Rotella T CI4+ 17.937
- Pelican18TQA4 06/04/09 CBEA Factory 22.553
- Alnmike 05/05/09 CBEA Factory 25.827
- Hurst89 03/22/08 BRM Elf DID 505.01 28.005
- PalosParked 05/02/09 CBEA Factory 30.642
- DidJettarun 03/24/09 BRM Motul Specific 505.01 39.645
- Shell Rotella T CJ4 5W40 API 2
- Amsoil DEO CJ4 5W40 API 2
- Mobil 1 TDT CI4+ 5W40 API 9
- TOTAL MC3 VAG 4
- Schaeffer S9000 CJ4 505.01 5W40 API 2
- Mobil TDT CJ4 5W40 API 2
- Mobil 1 Delvac ESP CJ4 5W40 API 5
- Elf LLX 504/407 5W30 VAG 6
- Mobil 1 ESP 504/407 5W30 VAG 4
- Castrol Pro 505.01 5W30 VAG 4
- Castrol SLX III 504/507 5W30 VAG 5
- Shell Rotella T CI4+ 5W40 API 7
- Elf CRV 506.01 0W30 VAG 4
- Amsoil AFL 505.01 5W40 VAG 3
- Elf DID 505.01 5W40 VAG 6
- ELF LSX VAG 4
- Motul Specific 505.01 5W40 VAG 4
- FACT VAG 3
Date:
Engine Code:
Miles/Hours oil:
Miles/unit:
Oil Type:
Fe Iron:
Cr Chromium:
Al Aluminum:
Cu Copper:
Pb Lead:
Sn Tin:
Ni Nickel:
Mn Manganese:
Top off Oil:
