aslspiderman
Trying to understand
So I just purchased VCDS and did a IP reseal. Doing some research on what proper IQ and timing should be, I ran across this thread. Prior to finding this thread, I found info that told me to run IQ at 3mg/st and set timing above center on the timing scale.
I have read through this thread and everything is still very fuzzy. So I took some shots of current settings, in the hopes that I can increase my knowledge with the help of those with more knowledge here.
The car is my 02 Jetta. The motor is bone stock, with 203K miles on it. Everything is original (other than TB and associated parts).
IQ is set at 3
So here are some current readings:
Honestly I don't have enough knowledge to ask relevant questions. Looking at aNut's readings:
1. Should start of injection be .4 or is it relative, as long as requested and actual are the same?
2. Will adjusting my timing down, reduce start of injection?
I have thick skin so you can flame/chide/laugh-at. My goal is to increase knowledge and hopefully be able to pass on my gained knowledge.
Thanks in advance for any help.
IQ is set at 3
