So much like the OP noted my timing graph had only the vertical yellow line to start with (didn't think to screen grab that one sorry), so I bumped the timing more advanced to "bring the graph around."
This is the initial graph and Group 004 readout.
Couldn't get the graph and data blocks to play nice and show up at the same time so I took two separate screen shots.
Here is the graph showing the vertical and horizontal lines very near the blue diagonal.
Here is a screen shot of the Group 004 data blocks, again after the 2nd tweak. You will notice that I managed to get the specified and actual injection nuts on, but my Cold Start Injector Duty Cycle is 39%.
Not sure if the OP is following this thread anymore but how does this look? What do people think? Total time on this was maybe an hour tops.
That being said the temperature did fall off as I was diddling with the car off and on, so tomorrow I'm going to drive it for about 40 minutes and throw it on the VCDS again...
Later!
