Not sure what you mean by "timing belt marker"??
The overall process is process is:
- cam sprocket slightly loose
- three IP bolts slightly loose
- transmission at TDC pointer
- cam locked with locking tool
- IP hub pinned with locking pin
then:
- Install belt
- tension belt (cam sprocket and IP sprocket may move slightly, by design)
- tighten cam sprocket using counterhold, tighten IP bolts, confirm transmission pointer has not moved
- remove cam lock bar and IP locking pin
- rotate engine 2 full turns using crank bolt, stop at TDC and confirm locking pin and cam lock will go back
The process is covered really well here:
http://pics3.tdiclub.com/pdf/a4timingbelt.pdf
