TDI timing belt replacement expense
jnc7608
NY/NJ
2013 Jetta TDI
Hi All -- I've been quoted $2800 by two VW dealerships in NJ to replace the timing belt on a 2013 VW Jetta TDI (114,000 miles). A third dealership quoted me $1900. Both of these prices seem very high. Does anyone have any insight here? Why the two different prices, and why are both so high? I know it's a lot of labor, but that much?
AverageAndy
Phoenix, AZ
2013 Passat TDI SEL, 2013 Jetta TDI 6MT
Replacing the timing belt is a lot of time and quite a few parts, including the water pump. To do it yourself requires $265-$320 worth of parts, $119-160 worth of specialized tools, coolant, about 4-5hrs and patience. For me, because it was my first time and I didn't have VCDS to purge the fuel system, I also used an indy mobile mechanic ($120) to double check my work. It ended up being under $700 total (my kit is a little more expensive -Passat), so I figure double at a dealer, say $1200-1400 seems about right, but I don't know if rates are higher in NY/NJ. For sure, $2800 is too much.
jnc7608
NY/NJ
2013 Jetta TDI
Thank you very much for your insight. I'm planning a trip to Chicago over the weekend (800 miles each way). I have an appointment at the dealer who quoted $1900 on Friday. I may do that. I don't want to let the car go longer, even though I think the owner's manual recommends a change at 130k miles.
AverageAndy
Phoenix, AZ
FWIW I did mine at 133K miles. I think others who do it earlier usually have had to replace a leaking water pump and doing the timing belt at the same time makes sense since it is already off.
jnc7608
NY/NJ
2013 Jetta TDI
Thank you, again. Maybe I will wait. I have a mechanic I mostly trust, but he can't get to it until I come back. I'll have to think about it. Yes, I'm prepared for the water pump.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Buy the kit and replace everything. Get it right the first time. The general rule is replace everything the belt touches. Maybe more. Be aware of any one time use bolts used. Make sure it is someone who actually know these cars. Good luck!
jnc7608
NY/NJ
2013 Jetta TDI
Took it to the dealership that quoted me $1900 this morning. They're sticking by it. Still probably robbery, but I want to get it done before I leave for a long trip on Sunday. I have a hunch the diesel technician there is experienced. We'll see.... I'm not mechanically inclined myself (obviously). Next time, I'll have a better non-dealer mechanic lined up.
Thank you all for your input, and feel free to keep the advice coming.
jnc7608
NY/NJ
2013 Jetta TDI
FWIW, I talked to a dealer in Cleveland yesterday, and they quoted me $2100, and said it would be a day-and-a-half of labor. Maybe the dealers don't have mechanics who know how to work on diesels anymore in addition to being crooks.
thatwhitejsw
Clermont, FL
MK6 JSW TDI
My local Euro shop charged about $1200 when I had it done a few months back. Little shops have less overhead so if you can find one they'll be a lot cheaper
drew_t
SF Bay Area
2013 Passat TDI SE
The fact that it’s a diesel engine doesn’t really enter into it, for purposes of this job.
It took *me* the equivalent of a day and a half to do mine, and I had never worked on one of these particular engines before, and I took my time. I’m sure the dealer techs, with the benefit of experience, power tools, a lift, etc., can fly through the job.
I do hope you’re making sure that the less expensive dealership is going to replace all of the components that the two more expensive ones were, especially the water pump.
JoeAverage
Reading PA
2006 Jetta TDI
A friend has a 2006 Jetta TDI. She thinks the timing belt broke. Does that car have a belt or a chain? If it's a belt and broke while driving, how likely is it that valves are bent and/or pistons were damaged? Appreciate any advice.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Belt and if it broke it is highly likely damage is done.
JoeAverage
Reading PA
2006 Jetta TDI
Just have to look in there. Remove the belt guard. Could be broken or stripped teeth and such.
Thanks. I do basic stuff on my Hondas/Acuras, but never worked on a VW. I'm sure YouTube can walk me through that. One thing that's universal, if the belt broke and damaged the engine, it's not worth repairing.
Anybody want to buy it?
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Not necessarily. It needs to be checked really before being written off like that. What were the conditions when the belt broke? A fair number of people have recovered from this kind of thing.
pedroYUL
MI, USA
2004 wagon BEW; 2015 Passat CVCA; 2015 GSW CRUA
Unless it is a New Beetle (BEW), the 2006 engine code is BRM, single overhead cam, 2 valves per cyl.
Valves would need replacing, but usually that is it. New valves, followers, new camshaft would be good, that's it.
...or:
JoeAverage
Reading PA
2006 Jetta TDI
...or:
Thanks. But add in the belt, etc you're talking over $2K in parts. For a car with 236K miles, is it worth it?
Nevada_TDI
Reno, sort of...
2001 Jetta TDI
Most TDI's with regular service will run well past 300k or more. Is it paid for, is your insurance reasonable?
Even if you only drove your TDI for two more years; divide $2000.00 by 24 months for example equals $83.00 a month, what else can you drive for $83.00 a month that produces the fuel economy your TDI does?
AndyBees
Southeast Kentucky
I'm an old man that COVID has left tired, (fatigued is the word) stiff and slow. I did a complete TB job on a 2012 Jetta this past December. It was the first TDI TB job later than a 2006 that I had done. I was a bit hesitate to do the job. But, it was for a friend. I actually think it was easier than doing a TB job on an ALH.
I did it in about 10 hours from the very beginning to the end.... seems his total bill was about $750 as I did do a few other things to the engine.
JoeAverage
Reading PA
2006 Jetta TDI
Thanks. Was that after the belt broke though? Where there might be head/valve damage?
