1 year update
I finished the truck as a Father's Day present to myself in 2013 so I've just surpassed the 1 year mark.
I've been very happy with the results of the swap. Every time I get in the truck I enjoy the work and time I put into the effort. I've been keeping track of every drop of diesel put in the truck and at just under 10k miles I'm averaging exactly 38mpg and keep in mind I've used this truck as a truck.
Only a couple issues so far with the swap:
1) Only electrical "gremlin" was laughable when I forgot to tighten down the little nut on the fuel shutoff solenoid.
2) The truck is running a little hotter coolant temps than I anticipated. I'm not sure if it has to do with the design of my cooling system, pump cavitation, or clogged core from the wrecker yard car. All I know is there is no way I can hook up my a/c system with the coolant running as hot as it is - would only exacerbate the issue.
Minor non-swap related issues:
1) my non-oem coolant flange on the end of the head is warped slightly and leaks small amounts of coolant
2) back edge of my valve cover weeps a little oil
3) As soon as I installed my r520 nozzles I have been having an issue with leaking return hoses when I do hard WOT pulls
4) my driver's side inner tie rod is SHOT. Need to replace that guy asap.
Or course I need to get going on stage 4 (gtb2056, 11mm IP, retune) so I can have some more fun.
