Boost lag
From time to time I was noticing that my boost wasn't behaving nicely. Since I hadn't yet checked for boost leaks I made up a couple adapters to get that done.
And here they are with my regulator
In action
I also hooked up the steel blockoff plate to the turbo outlet to see if I was leaking anywhere on the exhaust side. I wasn't expecting to find anything since I had zero soot traces but I figured it couldn't hurt....well it almost did. When I pumped up the pressure to around 40psi it actually started rolling the engine over and driving the truck UP my driveway.
Anyway, no leaks on the exhaust side but I did have a leak on the cold side right here at around 30psi. No I'm not hitting that level of boost now...but hopefully will be sooner rather than later.
I did also did a couple logs to see what was up:
In my first log you can see two separate 4th gear logs. The first was taken after a long run without using the brakes and shows good boost response. The 2nd was done after sitting at a stop sign (purposely depleating vacuum) and shows slow or laggy response which of course indicates that my actuator isn't seeing full vacuum at low rpms.
Here is another log showing reponse in 2nd, 3rd and then 4th gear.
The first thing I checked was my vacuum supply to the n75 which was lower than normal (15" Hg instead of the 25-28" that one should see). I traced this back to a loose vacuum pump nipple. I siliconed it up as a temporary solution to give me 20+ inches of vacuum.
Oh I also made a quick visit to Jfettig to get an updated tune from Malone. With the boost coming in early like it should thanks to fixing the vacuum leak, fixing the boost leak and most importantly getting the tune updated this thing now pulls!
I can't wait to see how this thing moves when I throw some more fuel and boost at it.
