James & Son
I have had another day to think about this. The center dot wear issue is exactly that. The center dot. Look at my #1 follower which has been in for about 55000 km (not much).
The center dot is tore rate out. The black and the metal below were tore rate out. A perfect dot. This is the center of rotation.
The trouble now is that I believe there is two places where this wear dot phenomenon is taking place. Where the injector fires and the follower takes the injector force instead of the bearings( this may happen at low speeds, oil viscosity may have an effect as well on bleed rate). This is what is shown above.
The other place is the point where the apex of the lobe and cam shaft center line, lines up, with the follower center line and you can see the center dot marking on the nose of the cam.
So unfortunately what i suggest above will supplement what I have already done and for me might not even be necessary since i believe i have stopped the follower loading by other means(which are beyond DIY). But the suggestion is valid and a .002-.003 inch taper from the edge where the galling is taking place to the cam face center in that area may relieve the high loading( idea is to remove the galled area only but with a very mild relief so the rotating side of the follower takes more of the load). But the more I think about it the more it could have disastrous results without control over how much cam bearing clearance and therefore how much up and down cam movement can take place.
I guess I have to back off on a low cost DIY.
In a nut shell this should improve follower life.
1) reduce valve spring pressure by 15% so that injection spring pressure is greater and prevents the #5 journal from lifting or orbiting around.
2) relieve the #3 bearing to eliminate the possibility of #3 bearing acting as a fulcrum causing a tilting action to take place depending on which injector is firing. In other words #3 must get pounded down as fast as necessary so that #4 bearing acts as the fulcrum instead of #3. This prevents the firing of #4 injector from lifting the cam belt and the journals of 1 and 2.
Now the bearings will take the injector firing loads instead of the followers.
Further to the above. If one does the above then you could relieve the galling as i have suggested to further supplement any possible injector loading being transferred to the followers.
The answer to the lobe wear dot point is what eddif, Franko, others(A5Inky and Jnitrofish to name a few) and myself have done, can't say what the long term is for that but I know this. Do not reduce the bearing area of #1 and #2.
CJ4 oils with an ounce of zddplus seem to be the simplest most effective for the first 30,000 to 50,000 km or use the standard no load break in method.
Edit: I forgot, one of the most important things that has a pronounced effect on the follower loading is the thermostat. The thermostat loses 2 degrees per year and my 6 year thermostat was making a 40 wt into a 50 wt. which would have a pronounced effect on follower leak down.
