TDI Injectors replacement
Puller85
Kentucky
1.9 TDI
I'm looking to put new injectors in a ALH. I was going to have them custom built for a better injection pump and a bigger turbo. Is it better to rebuild the factory ones or is there a better easier option? I know on some CAT engines you can run John Deere injectors and make more power, just curious if you could do the same for the ALH?
Mozambiquer
Versailles Missouri
Yes, you can. Talk to @Franko6 he does a good job of doing injectors.
dhangejr
PNW is my home
mk4 Jetta
I have some ised injectors that will give you more power. They are best with a tune you will smoke with out them bit s bigger turbo will clean it up an IC even more so (m
dhangejr
PNW is my home
mk4 Jetta
In short the answer is yes lots of peole drop nozzles on factory stocks , NUT this can and eventually will damage the engine. I seen my friends Cummins melt from over fuel…so
Mongler98
COLORADO (SE of Denver)
It's best to do a hot swap with kerma or send them out to be done by a proper vendor who can pop teat and shim tune them with 2 stage setup. Not many have this ability. A DIY is risky but it's cheap.
Talk with a tunner and search and read thes forums. Plenty of usefull info here to educate yourself with
