TDI in Mk1 Cruise Control
Sirmeeps
Wilmington NC
97 Jetta Tdi, 81 Caddy Td
So I put an AHU into my Caddy last year and kind of rushed the swap. My wiring is messy and its time to go through it.... I want to have cruise when all is said and done. Just wondering if anyone has any good info on setting the cruise up in a mk1. Also id like to know if anyone has really simplified the wiring in their swaps like mine. IE only running what is neccessary to run the car. Thanks guys!
BigVWman
Apex, NC soon to be back in the mitten of doom!
A1 cabriolet tdi and 01 nb tdi and countless gassers!
Its actually fairly easy in my opinion. The ecu does most of the work but it will need to see a speed signal, and pedal switch positions. I used a stock switch. Mine I used the mk1 cluster but input the vss in the back for a speed signal since i also used a 020 trans(hate) and then its a later cabriolet so it had pedal assembly accommodations for an extra switch it takes three or two with a relay. One on clutch and two on brake pedal.
Sirmeeps
Wilmington NC
Forgot to mention Im running a CE2 swap with the mk3 stalks. Mk3 cluster and using the 02a as well. What all am I gonna need?
