Ol'Rattler
Subscribed...........
Exact same experience with mine.Ah, makes sense now. In my case, despite running the full set of 034, the dogbone was the first to go. Tranny and motor not long afterwards.
Well, i have owned a stage 1 BFI gasser setup in a MK4, i have rode in a Stage 2 BFI gasser, and i have rode in a BSH gasser setup as well. The BSH was the most physical viberation, the BFI where nearly the same between stage 2 and 1 except while driving there was more noise on the stage 2. I have never been in a upgraded mount tdi before so i have nothing to compare it to except gassers...Storx, have you had any experience with Vibratechnics? If so how do these compare?
I know any uprated mount is probably going to increase NVH and I can live with a little extra but I dont want crazy noises and a dash thats trying to shake itself loose.
Alex.![]()
I'm not surprised there's more "noise", surely higher frequencies are going to pass straight through the spring?
Those spacers are scary enough, definitely would not add any softer material in there for any reason. The engine is hanging from them!...Hey I was looking at the solid metal spacers. Can you sandwich in grommets to absorb the higher frequency resonance?
In that configuration they are in tension, which is where bolts are very strong. Porperly torqued there should be very little shear forces.Those spacers are scary enough, definitely would not add any softer material in there for any reason. The engine is hanging from them!
I would.Those spacers are scary enough, definitely would not add any softer material in there for any reason. The engine is hanging from them!
I redid the thread as a review for easier finding.. for specific mount.. but the spacers dont really hold anything up.. the bottom of the mount sits in a pocket and the spacer nearly float there to fill the space to prevent the ears of the mount from bending off.. Down... the kit comes with shim spacers to make sure the spacers are perfectly flush with the mount..Those spacers are scary enough, definitely would not add any softer material in there for any reason. The engine is hanging from them!
"for a while" ? Why did you change after that and what did you end up going with in the end for your TDI?I did OEM mounts with the BFI stage 2 dogbone for a while. Vibrations weren't bad at all. Very nice setup, actually.
