slutzrrtrux
Hey-
I'm gearing up to put a tdi engine into my diesel rabbit pickup 81. I'm new to a lot of this and have some questions:
Does anyone have recommendations of resources/things to read that are in fairly plain language that will be helpful? We are backyard.
Which engine would be most ideal for the most simple swap?
I've been looking at a 96 passat as a donor car, it is 1.9L IZ I believe. Also looking at a 98 jetta.
Also, someone recently told me that if I use the passat, i'll run into some kind of issue that I don't understand involving the injector pump cable. I'm planning to use the pump out of the donor car, not the one in the caddy.
Real dumbed-down language, resources and any advice much appreciated!
<3
<3
