My 2015 TDI clogged its heater core at 81k miles. I had flushed the system shortly before it clogged as part of a water pump replacement. After I put the new core in it clogged again in a few weeks. I removed the core and back flushed it with Preston radiator cleaner. I also flushed the system with another 2.5 gallons and put a temporary filter in the coolant return line to see if it would catch any junk in the coolant.
It did.
I cleaned that filter about 15 times and it was still removing material from the coolant. As such I decided to try adding up a more permanent filter. I bought a "Coolant Filtration System for 5.2007-2012 DODGE RAM 6.7L Cummins Diesel Turbo" on ebay for $49 and from the kit I really ended up only using the filter housing, filter and the mounting bolts.
I was considering drill the mounting holes in the filter housing all the way through so it could be mounted from up top but decided against it in case I screwed up the threads. Instead I made my own bracket from a cut down corner shelf bracket I had around.
The positioning of this is *tight*.
Test fitting...
I used 3/8" MNPT nut to 1/4"FNPT adapters and then 1/4" MNPT to 5/16" hose barbs for the housing.
For the inlet to the filter I took the hose from the coolant reservoir return off completly and connected the hard fitting on the engine to the filter with 5/16" hose.
As a test run to make sure it was flowing coolant I ran a clear tube from the outlet of the filter back into the reservoir and looped it so I could see it while it was running. Not a lot of flow at idle but it flows more once it gets above idle. This is the first run so the air is from the filter filling up.
https://flic.kr/p/2nXBTb3
From the engine side...
https://flic.kr/p/2nXAtuU
The dripping from the filter is due to the vinyl tube being too large so the barb wasn't right for it. This was just for a test.
Plumbed in for real with 5/16" hose.
Hopefully, as the coolant is circulated through this over time it will get any remaining or future gunk out of the coolant.
Concerns/areas of improvement...
To remove the fuel filter or to service the AC the coolant filter housing has to be moved. Also, to change the coolant filter the housing needs to come up as I don't think there is enough clearance to unscrew and remove it between the bottom of the filter and the AC lines.
Two mounting bolts for the housing and it is free. Ratcheting wrenches make install/removing the filter housing easier. If I had drilled it to be top mounted this would be easier still. I left extra slack in the hoses to make this easier.
The filter position is tight to the engine. I have about an inch of clearance between the bottom of the filter and one of the engine mounted hoses. Hopefully that is enough to account for engine movement. I am looking for a shorter coolant filter to get more clearance there and to also hopefully be able to change it without having to unmount the housing. This was the only space I could find for the housing, at least from the top of the engine. I didn't go looking above the splash guard. The filter housing can have the outlet on either side. It *might* have been possible to rotate this 90 degrees clockwise and have a 90 degree barb on the other side but it would be very tight that way too.
Shawn
It did.
Test fitting...
Shawn
