Took me forever to track this down after I saw it once - maybe you have it linked in the OP but I couldn't find it.
Pin map (pin mapping, pinout) for 68 Pin AHU or 1Z ECU:
Pin# Colour Function
1 Brown Ground
2 Black/Green Tachometer Signal to Instrument Cluster
3 Not Used
4 Brown/Yellow Quantity Adjuster Pin 6
5 Brown/Yellow Quantity Adjuster Pin 6
6 Black/blue Coolant Glow Plug Relay Single
7 Gray/Green Modulating Piston G149-2
8 White Engine Speed Sensor G28-2
9 Not Used
10 Not Used
11 Blue Needle Lift Sensor G80-2
12 Gray Needle Lift Sensor G80-1
13 Brown/Red Mass Air Flow Sensor Pin 6
14 Blue/Brown Coolant Temperature Sensor G27-1
15 White/Blue Throttle Position Sensor Pin 1
16 Blue/White Oil Pressure .3 Bar F22
17 White/Red Clutch Switch F36-2
18 Yellow/Red ?
19 Red/Green Mass Air Flow Sensor Pin 1
20 White/Yellow Brake Light Switch F47-1
21 Not Used
22 Not Used
23 Black/Yellow Switched B+ from Relay 109 output
24 Brown Ground
25 Brown/White Exhaust Gas Recirculator Valve N18-2
26 Black/Brown Coolant Glow Plug Relay Dual
27 Not Used
28 Brown/Green Air Conditioning Relay
29 Violet/Black Modulating Piston G149-1
30 Green/White Glow Plug Relay J66 Pin 7
31 Blue/Yellow ?
32 Gray ?
33 Brown/Blue Sensor Ground
34 Blue/Gray Cruise Switch E45-2 Resume
35 Red Cruise Switch E45-3 Set
36 Not Used
37 Green/Gray Air Conditioning On (Signal from AC system)
38 Black Ignition from Key switch
39 Red/Black Alternator Load Signal DF Pin 2
40 Not Used
41 Not Used
42 Black/Violet Power Relay J317 (109)
43 Blue/White Vehicle Speed Signal Cluster Pin 7
44 Black/Red Brake Light
45 Black/Yellow Switched B+ from Relay 109 output
46 Brown Ground
47 Red/Blue Wastegate Control Valve N75-2
48 Blue/Green Glow Plug Light
49 Brown/Yellow Quantity Adjuster Pin 6
50 Yellow/Blue Glow Plug Relay Pin 1
51 Brown/Black Cold Start Injector N108-2
52 White/Green Modulating Piston G149-3
53 White/Black Fuel Cutoff N109
54 Not Used
55 Green/Red Throttle Position Sensor Pin 3
56 Not Used
57 Green/Yellow Throttle Position Sensor Pin 2
58 Not Used
59 Blue/Black ?
60 Yellow/White Malfunction Indicator Light
61 Gray/White On Board Diagnostics Connector Pin 7
62 Green/White Throttle Position Sensor Pin 5
63 Yellow/Black Fuel Temperature Sensor G81-1
64 Blue/Yellow Intake Air Temperature Sensor G81-1
65 Green/Blue Throttle Position Sensor Pin 4
66 Black/White Cruise Switch E45-4 On
67 Not Used
68 Black/Yellow Switched B+ from Relay 109 output
Credit
Alchemist,
download in word file.
