No. It's an advance of the cam shaft. A clock wise bump on the 18 mm bolt.Don't you mean from 4.9 to .5?
I didn't think it would run well at 4.9. then again mine ran fine at -4.4. hey whatever works.No. It's an advance of the cam shaft. A clock wise bump on the 18 mm bolt.
Fran, I have a Skoda Octavia TDI PD BXE also! And have the same will of adjusting it after 70.000 km .Thanks again! Without this post I was going mad!!!
Now its at 0.0º and varies to -0.5º under hard acceleration. Now my car Is alive again!!
The strange thing is that older PDs are different. I am used to old PDs, and I was going the wrong side. Now everything is fine, and I am happy that I didn't broke anything.
Good fuel consumption, lower temperatures (water, oil... and I suppose EGT), and black smoke is back again!! My car is chipped so it's smoky,
Thanks everyone who posted at this post. It really helped me!
RGDS from Spain!
Correct sir, make the adjustment on torsion then go to block 14 and see how close the 4 values get to each other and to zero. A finely tuned injector balance should, in theory, provide best power to consumption ratio.Andre, do you mean to watch block 14, watching to see if the values get closer to zero?
SIR? I'm too young to be a sir.Correct sir, make the adjustment on torsion then go to block 14 and see how close the 4 values get to each other and to zero. A finely tuned injector balance should, in theory, provide best power to consumption ratio.
Great information! Please keep us informed about further finding on this.Hello to all,
Well, I have been following this subject for a while, and decided to experiment with it. I bought a torque key, a special tools for turning camshafts, and read a lot. Rented VCDS software and inteface also, of course.
Here are my outcomes:
Torsion value fuel consumption km/lt (flat, cruise control)
-1,5 0.6 lt/h 36.3 km/lt in 6th, at 70 km/h
+0.5 0.8 lt/h 34.1 km/lt same conditions
0.0 0.4 lt/h 45.1 km/lt same conditions
Let see if that is possible: First, let us define what would be an out of range value? I have read some people get over abs(4) for torsion value. I just moved it to the opposite direction I did before, and I was at +0.5 . I made my marks when the first test, and I use them as a reference now. I am just a little out of the original (factory, initial) mark, but to the opposite direction.Great information! Please keep us informed about further finding on this.
Also, are you sure the 0.0 torsion value was actually 0.0 and not "out of range" reading?
Originally my torsion was -0.7 when I had some juddering. Set it to +1.1 which didn't help and gave it uneven idle.Steve, it's such an easy adjustment to make, you would be the best person to tell us. Change it back, see what happens and let us know.
Thanks for posting this!! One more question; could you please do this test: engine warm and idling (like above test). Check your Block 004 field 4 (the Torsion value). It should be 0, right? Then rev the engine in neutral to 2500-3500 RPM. Does the torsion value change? If yes, then how much? Thanks!!Let see if that is possible: First, let us define what would be an out of range value? I have read some people get over abs(4) for torsion value. I just moved it to the opposite direction I did before, and I was at +0.5 . I made my marks when the first test, and I use them as a reference now. I am just a little out of the original (factory, initial) mark, but to the opposite direction.
My impression is that it is on 0.0 The instrument says that, also.
Besides, if it was out of range, wouldn´t it be a very bad fuel yield and even pistons beating valves?
Here is a copy of VCDS log at idle, after the test trip (the test was long, involved other tests):
19:39:33
819 /min Engine Speed (G28)
4.1 mg/str Injection Quantity
7.1°KW Injection Duration (specified)
85.5°C Coolant Temperature (G69)
0.0°KW Torsion Value
14.3 mg/str Start Injection Quantity
48.0 Start Synchronisation
30.6°C Intake Air Temperature (G72)
0.07 mg/str Injection Quantity Deviation Cyl. 1
-0.14 mg/str Injection Quantity Deviation Cyl. 2
-0.02 mg/str Injection Quantity Deviation Cyl. 3
0.12 mg/str Injection Quantity Deviation Cyl. 4
Best.
Oldbeaver
The juddering (misfire) is still there but substantially 'softened', nearly un-noticeable. The uneven idle when it's cold is still there. Clearly I must do further research and look, or start, another thread.Originally my torsion was -0.7 when I had some juddering. Set it to +1.1 which didn't help and gave it uneven idle.
So today played around and set it to -1.1 - was so slow I thought the MAF had blown again! Tinkered around and got it 0.0 Going to work in a while and see how it performs.
From my reading I gathered that the closer the idle values are to zero (and consequently to each other) the less the ECU has to adjust injection quantity in each cylinder to keep a smooth, quiet idle. This fine tuning translates into better atomization at idle and, to my mind, across the whole rpm range.Andre, I want to play with this some more to see what I come up with. I'm thinking about those numbers as an aggregate will come out close to zero, regardless of how far off one is from zero. I can see if it gets the numbers all closer to zero, then the idle may be smoother, but I don't see how it can effect fuel consumption.
So if it's slow at work tomorrow, I may play with it a bit more and see what else I come up with.
I played with it yesterday and it definitely changes the IQ at idle.
So I got much bravery and decided to do the adjustment. I warmed up the car and took a try. These are values I got while trying: -2.4, -0.5, -3.4, 1.0, 0.5, 2.4, 0.0. What is strange that momentary fuel consumption was 0.6 L/h for all but -3.4 ant 2.4 values. While it had -3.4, it started with 0.6 L/h and after ~1,5 minutes of idle I saw 0.4 L/h. With 2.4 I saw 0.8 L/h consumpion. Finally I decided to leave Torsion alone at 0.0.Torsion value fuel consumption km/lt (flat, cruise control)
The data is too long. I can send it to you if you tell me how. In summary:Thanks for posting this!! One more question; could you please do this test: engine warm and idling (like above test). Check your Block 004 field 4 (the Torsion value). It should be 0, right? Then rev the engine in neutral to 2500-3500 RPM. Does the torsion value change? If yes, then how much? Thanks!!
