Dieselboy
- Joined
- Jul 3, 2012
- Location
- Kutztown,Pa moved to Madrid,NE
- TDI
- 2002 Jetta TDI, 1981 Caddy Tdi ALH Swap
Hello guys wondering where a good machine shop in eastern pa is that can bore out an ALH block.
This is determined by the pistons used when the crank stays the same. The CR could be maintained, or reduced to mitigate peak cylinder pressures in a high boost build.... you would be completely changing the compression ratio by increasing the cylinder volume...
All else being equal? Yes it does.... Increased volume doesn't always mean more power.
BHWs or Crafters are a better choice for future buildup of an ALH/ASV
I had the +5mm ASVs. Now running BHWs. More displacement is always better as long as cylinder walls don't get too thin
You can get BHWs cheap now. Check out the deal Jim found here:
http://forums.tdiclub.com/showthread.php?t=377418
Depends on budget and goals..So it would be worth boring my block and putting in the bhw pistons?
