S
SkyPup
Guest
Here is some info and a URL of the first complete new TDI failure that I've heard of. It seems to have been due to a "manufacturing problem acknowledged by the dealer" I posted it here to see if anyone else has experienced similar problems?:
Bad Things That Happened To My (98 TDI) Car
April 14, 1999 The car is back! New engine, new name: Jesus. The ABS checked out okay (yeah, right). Time to start yet another break-in period. Also, the courtesy light has been fixed, and I'm told a new stereo will be ordered. We shall see. For some odd reason, it's now difficult to shift into first gear. Hm.
April 6, 1999 In an effort to revive my car, the dealership is replacing the engine (with the so-called "long block"). I have also instructed the repair of the mysterious stereo voltage spike, the sloppy and noisy ABS system, and the finicky driver's side courtesy light.
April 5, 1999 The engine problem has been diagnosed. The dealership admits to a manufacturing problem in the (aluminum) cylinder head. The porous nature of this piece allowed the pink coolant to seep through to the oil and into the injectors. Besides fouling the injectors, it apparently also trashed the rings. Probably explains the loss of power I detected in February, eh?
March 30, 1999 The death of my car. You know, it seems that bad things always happened on the way home from work. My car started shaking, so I pulled over and popped the hood. The engine was trying to dance out of its mount. The service guy at the dealer said he hadn't seen anything like it. Still not sure what happened, but I lost total compression in two injectors, most in the third, and have a coolant leak in the fourth. They think I'll need a new engine. Meanwhile, they rented an Olds for me to drive around in (and told me it would be quite a while). Yuck. My car had about 4800 miles on it when this happened.
February 10, 1999 Strange loss of power. Felt like the turbocharger wasn't working. Weird. Changed the way I drove (specifically, I started shifting into a higher gear at 2000 RPM), and the problem seems to have gone away. I wonder if the turbo is supposed to kick out at too high an RPM. However, it seems that, after it kicked out, it didn't want to work at all. OTOH, it could be something else entirely.
The url of this is located at:
www.geocities.com/Hollywood/Makeup/4333/hfcmain.html
