rwolff
One thing I've read about is that in Ontario, there's a high probability that it will be mandatory for all diesel fuel sold to be blended with ethanol starting around 2005/2006. Through other sources, I've heard that the TDI can't handle the stuff. What's the scoop on using ethanol-blended diesel in a TDI?
One of the main reasons I was looking at a TDI was as (expensive) insurance against lack of fuel availability (i.e. can use B100, which is renewable). If it turns out that there's a significant probability that I won't be able to get fuel for a TDI, then my next car will be a gasser (if the fuel supply dries up, still has the possibility to burn alcohol by boosting fuel flow through bigger injectors/higher pressure/modified chip/some combination).
BTW, if I get a gasser, it won't be a VW. The one I'm looking at is normally aspirated (i.e. no turbo to blow up), and for the price of a Jetta Wagon TDI I'd be able to get a gas powered wagon plus (based on how much I drive and fuel that's significantly more expensive than now) about 10 years worth of fuel.
[ September 04, 2002, 04:01: Message edited by: rwolff ]
