blah-kay
Hey guys, my problem is that my car is jerking or stuttering for a better term only during acceleration. It's not a motor mount shake or anything, it feels like the car is cutting boost or fuel entirely. The jerks are violent but don't happen in rapid succession. It happens randomly so I can't diagnose it properly, which makes it frustrating. I managed to get a vag-com graph when it was happening (will post it below). I graphed IQ, the n75 %, rpm, boost, and throttle petal %. For the disclaimer, was afraid I wouldn't be able to figure out how to turn Exel into a graph (I couldn't figure it out) so I took a screenshot of the live graph. Only look at the beginning of the graph right before I let off the throttle. You can see there is a random cut in fuel and a slight cut in the n75 valve %. After this, I changed my n75 valve and still have the problem but seeming less prominent or as often. I have a boost gauge in the car and when the jerking happens, the boost drops, this would make sense if fuel is cutting. But, when the car is running properly boost is nominal and the wastegate works as it should keeping me around 14 psi, with no abnormalitys. I have an EGR delete for reference. I have not done a boost leak test. But within the past year, I have changed all the vacuum lines to silicon ones. Not sure where to start, I didn't want to start throwing piles of parts at it. I think it's either a fuel or boost issue, maybe both. Seeing what you guys think, and where I should start.
