Josh_WA
- Joined
- May 8, 2015
- Location
- Mountlake Terrace WA
- TDI
- 2014 Jetta TDI, 1993 Eurovan Weekender TDI(AHU) converted 2/2016, 93 Eurovan MV TDI(1z)(sold!)
After reading just about all the TDI into Eurovan posts from a few different forums over the years, I’ve decided that it’s my turn to delve into the fray. I had been liking the idea for some time, but just seemed out of my technical reach. We just bought a 2014 TDI jetta in the summer of 2014 and have loved the car. I think the enjoyment of driving that has pushed me over the edge to plunge into my deep end. And this is deep water for me. I have experience changing out wheel bearings, brakes, water pumps, gaskets and things of that level. Small pull and replace items. Nothing of this degree. But the internet has definitely evolved into any amazing library of information of how to, and lots of experienced converters who are willing to offer help. At this point, I’m working most of this project on my own, but do have a friend who will be loaning me his skills and engine lift to do the pulling of the old and placing of the new. I plan on completing the project by New Year if all goes as expected. I’m trying to keep this under a $2000 budget. We’ll see how that goes as well.
With that said, here’s what I’ve got going. My Van. 93 MV Weekender. Manual transmission. A little shabby when you look a bit closer, but not too bad. Out of a wild hair and inexperience, I ended up having a rebuilt Transmission put into the van. It’s a CPW. A little better final drive than the standard CHP. I also installed a .71 5th gear set. So having the van as manual already and my slight overdrive gear in, I thought this may be a little more manageable to complete the TDI swap.
I originally assumed I would amass my parts over a few years’ time. As timing would have it, an AHU engine popped onto the Craigslist, but not too far over the border in Langley, BC, Canada. It had already been pulled from an early 99 Jetta and included most of all that I needed from the donor car. $1500 Canadian, with amounted to about $1250 American.
Engine with all the normal built on accessories. (183K kms) 113K miles.
Wiring harness
Fuse panel
Downpipe
Potentiometer
Gas pedal
Air box
Intercooler
ECU
Intercooler piping and fuel lines
Promptly drove up and picked up my motor. Nice fellow who skillfully forklifted the engine into my van.
https://flic.kr/p/Vk5aDN
Just the day before I picked up the engine, I had secured an engine stand. With some backyard leveraging I managed to get engine onto the mount an into my work space, which sadly is my carport shed. It will do though. I stripped of the accessories and mounts. I cleaned the engine a good deal. I don’t have pictures, but the intake was caked with carbon and spent a good week or so cleaning that out. Same for the intake manifold. It was worse. I think I have it fairly well cleaned out though.
https://flic.kr/p/WxJiDb
So while I’ve been cleaning the engine up, I was collecting up some replacement pieces. ($400 spent so far)
Timing belt, idler, tensioner.
Serpentine belt, idler, water pump
Oil pan and valve cover gasket
New right, left and rear rubber engine/transmission mounts
New flywheel bolts
Diesel Fuel filter (wasn’t sure if I needed it, but have it now.)
Coolant
And acquiring the Euro parts ($500 spent) courtesy of FRANS with Dutch auto parts
4cyl transmission carrier 02B409905K
lower timming belt cover 028109127H
Oil dip Stick/housing 028115629E, N90461401, 044115611F, N 028 224 01
Oil filler neck and cap 044115308A/070115319
Sump (oil pan) 044103601D
Transmission upper cover plate 044103647B
right-side engine mount 028199207E.
to include these ABL parts I thought would be convenient
lift pump (fuel tank pump) 701919813B
Oil cooler bracket 028115417G (more clearance for drivetrain pan?)
I'm presently a little over budge at $2100 with problably some expenses to come. I'm hoping it all drops down below the 2k mark when I sell off my gas engine and accessories.
As of now, I’ve completed boring the new dipstick hole and have bore/tapped the right side mount holes. Also tapped the old dipstick hole to M12 with 1.75 pitch. Cut the end of an M12 bolt and slotted it. I will be red locktiting it. With the metal shavings mess out of the way, I’ve put on my ABL oil pan and gasket and installed my ABL oil pickup. Modified the windage flap to fit the oil pan as well. I shouldn’t have to flip the engine over any more.
[FONT="]Next step is to install the new timing belt. Will give the engine another good wipe down, and then pull the belt and accessories. I’ve managed to construct 2 of the 3 tools I think I need. Grinded down a flat bar a little to hold the valves in place and made a tensioner tool. My tensioner tool still needs a couple hardened bolts though. I ended up ordering the fuel pump locking pin. That’s coming in the mail.
[/FONT] https://flic.kr/p/Vk58u7
Wiring harness
Fuse panel
Downpipe
Potentiometer
Gas pedal
Air box
Intercooler
ECU
New flywheel bolts
Coolant
