Josh_WA
- Joined
- May 8, 2015
- Location
- Mountlake Terrace WA
- TDI
- 2014 Jetta TDI, 1993 Eurovan Weekender TDI(AHU) converted 2/2016, 93 Eurovan MV TDI(1z)(sold!)
Poor man’s 93 Eurovan MV TDI conversion
Here we go again. I previously converted a 93 MV weekender for my use via this thread.
http://forums.tdiclub.com/showthread.php?t=443865/
My goal on that build was to spend about $2k for the conversion. I think I ended up spending about $2300. This time my goal was to again spend around $2k, but to also include the van.
Earlier this summer I can across a great deal on a rear wrecked B4 Passat that somehow couldn’t pass up. I pulled the car apart and saved up the conversion parts I need for another VW Eurovan (T4a) conversion. I’ve sold enough parts to net a free 1z engine and parts needed. The Passat had the timing belt changed about 10k miles prior to the rear ending, so I’m forgoing changing belts and rollers if they appear good. I’ll do some inspection on the rotating items as I clean up the engine. The turbo unfortunately needs to be replaced. The whole backside of the engine has a nice coating of oil. The nice thing about going with the 1z from a Passat, is that the gauge cluster is physically the same as the Eurovan cluster. Also, the wiring harness for the 1z is not integrated with the lighting harness of the car, so the wiring is a little cleaner to begin with. I have more parts to sell, but as of now I’m at +$150 with the wrecked Passat purchase.
Passat parts needed for the conversion:
Engine
Engine accessories, including turbo
Coolant hoses and reservoir
Engine wiring harness
Matched ECU
Gauge cluster
Fuel lines
Eurovan tdi #2 by x Holmes, on Flickr
Just recently a van came on the market that would be an ideal candidate for my budget build. There are usually plenty of inexpensive manual transmission GL models that come up, but I was waiting for a manual MV. This one was going for cheap because it’s only running on 4 out of 5 cylinders. $500 later, I’m sweating home on 4 cylinders, to avoid a tow. I’m again going with a stock manual transmission. This one being a CHP this time, but will changing out 5th gear for the .756 in the Passat transmission. Stock 5th is .8xx. With, the van, I’ll be pulling out what is saved from above, to be replaced. The van itself is in fair shape aside from the slider door that I will be replacing. The inside needs a trim piece and just a general cleaning, but is not too bad. I can get those pieces from a local guy. That brings my van price to about 650.
The 3rd part of this puzzle of course are the European parts to make this bolt right in. The 1z and AHU engines are of the same block build as the ABL na diesel that is available in Europe. Frans will be supplying these parts again. Costing about $600.
4cyl transmission carrier 02B409905K
lower timming belt cover 028109127H
Oil dip Stick/housing 028115629E, N90461401, 044115611F, N 028 224 01
Oil filler neck and cap 044115308A/070115319
Sump (oil pan) 044103601D
Transmission upper cover plate 044103647B
right-side engine mount 028199207E.
lift pump (fuel tank pump) 701919813B
So far I’m at $1150 in cost. Additional $s to be spent mostly on the turbo, clutch package, and exhaust welding.
Engine
Matched ECU
Gauge cluster
Fuel lines
