jimbote
Certified Volkswagen Nut
Wait? You're still on stock 3.59 gears? I had those too when i first put the truck together. What a miserable gear set with 31s. 4.10 or 4.30 ftw. BTW: my first 4.10 rear drop was from a 1st gen Sequoia. All those are 4.10, and easy to find. Only difference is the pinion flange is harmonic and uses studs. Our driveshaft fits right on. My front came from a 3rd gen runner. Also cheap and easy to find. Swapped out the DD axle and tube for my stock units. The DD models use needle bearings for axle support, the lock hub models use bronze. But the manual axles fit fine.Yeah, I think this all makes sense. I'm on 33in tires, with 3.56 gears, and 0.81 final drive. At 70mph in 5th I'm basically sitting at 2000 rpm. If I drop down into 4th the temps drop too. Maybe loading up the engine that much at 2000rpm is just rocketing the EGT up.
I have 2 sets of 31in tires, but they are 15s and I can only run 16s with the Tundra brakes. TLR, no.
I don't typically do much more than 70-75mph. I was hoping to be able to chug along the interstate at 80 through the plains and parts of the West, but if that's just not in the cards for the truck/engine combo, I don't really have a problem with gearing to only do 70mph.
