TDI 1st Gen Tacoma Swap
PickleRick
Greenville sc
87 4 runner BHW swap, 2011 A3 tdi, several b5.5 bhw's.
I'm interested in how much your Taco weighs, they are rated less than 3500 lbs but I've seen many report 4200+ on truck scales with a mild lift and camper top.
I'm running in no MAF, only a MAP, I'm glad @burpod cleared up to why. I only see black smoke under heavy acceleration and even then it's not like Cummins rolling coal.
BimmerTim
Minneapolsota
ALH Tacoma
Last time I weighed it with me, my dad, the topper, bumper, and some of the camping cabinets with gear in them in the back it was just over 4000lbs. I remember laughing that it weighed the same as my B8 S4.
I'll have to remember to post back when the swap is done about the new weight. I don't imagine it will be much different.
BimmerTim
Minneapolsota
ALH Tacoma
Pretty productive weekend. I started by finishing up the welding on the downpipe. Here it is out of the truck so it’s a little easier to see.
Then I baked some engine mount brackets.
Next up was wrapping up coolant connections for the heater core. Here you can see where the heater core connections naturally land relative to the existing flanges.
First connection is the return line that goes into the back of the water pump. I bought a new hard pipe to start with, because the original one was pretty rusty. I cut it before it turns behind the head and remade the piping to turn away from the head and land where the hose wants to sit in the engine bay.
Then on to the heater feed line. I started with an Audi A4 1.8t aluminum flange for the rear of the head.
This flange has a flange where another water neck bolts on for the heater, but it faces straight back toward the firewall in my case. Initially I had a couple of flange plates made that I was planning to add a pipe and nipple to, so that I could retain the bolt on flange. That would keep the water housing unmodified and easily replaceable. However, there really wasn’t enough space to the firewall, so I ended up modifying the water housing itself… It is aluminum, so it shouldn’t be a part that needs replacing, and I really hope it doesn’t bite me. Worst case, I do have a plastic housing that could be installed in an emergency, but it would bypass the heater.
For the modifications, I chopped the water neck flange off and filled the hole, then I machined a piece of 3/4” aluminum bar to have a 16mm nipple on the end. I welded and tried to blend that nipple pipe to the top of the water housing and drilled through at the very end. I waited to drill the bar out, so that I could bevel the weld area and have the most penetration possible.
I prepped the water flange and the thermostat housing for powdercoating, but I ran out of powder, so that will be next week-ish.
I also replaced the rear main seal and bolted the oil pickup tube and oil pan on for good. I didn’t grab a pic of it for some reason, though.
PickleRick
Greenville sc
The profile looks really close to that of the BHW coolant block other than the small port running along the largest one. On the BHW that particular port is next to the temp sensor.
Although it's not likely to fail. Usually when the plastic ones fail is due to the plastic deteriorating. The tandem pumps on the PD engine like to weep oil which doesn't seem to make the plastics or hoses happy
bigsexyTDI
Kentucky
'98 NB x2, '01 Jetta x2, '03 NB, '04 Jetta x2
What a build thread! Nice job so far sir. Can't wait to see it finished up. Burpod I need to PM you about a MAF question.
BimmerTim
Minneapolsota
ALH Tacoma
I have been working on this pretty regularly, but mostly not interesting low visual appeal parts; New diff and trans seals, rebuilding and reinstalling axles, etc.
Some of the more notable items.
I ordered a custom radiator in April with an eta of 3-4 weeks. 10 weeks into waiting they were still telling me another 2-3 weeks, so I canceled my order. The plan is now to build my own. I found that OG Honda Civic half radiators have a close enough core size to what I need that I’ll be working off of that. I found the cheapest possible 4-core civic radiator to Frankenstein.
I started with a rough idea and layout of what I wanted. Intercooler on the passenger side, radiator on the driver side.
I refined until I had an idea I could actually fabricate. The green is the final radiator, the red is the final intercooler, and the yellow is a frame with the same dimensions as the stock radiator that both can mount to in the factory location.
I “needed” both the inlet and outlet on the same side of the radiator, so I added an internal baffle to direct the inlet flow to the passenger side of the radiator before it flows diagonally through the core to the outlet on the drivers side. The inlet/outlet/bung locations are being fabbed with 1/8” holes in their place to make the parts more rigid for bending. I’ll cut the final holes once the parts are here.
The intercooler is a similar design except that the internal baffles just help to guide the air through the cooler.
The radiator and intercooler are bolted to the yellow frame via threaded standoffs welded to the face of the end tanks. To make sure the standoffs are in the perfect location and to aid in the yellow frame assembly I designed a little assembly jig as well.
Part should be here for the rad and intercooler right after the 4th weekend.
This has been done for a bit, but I adapted the high-pressure power steering line to -6an and made up a high-pressure line with Earl’s PS fittings and line.
Next I gusseted my uprights, reinstalled the tubular upper arms, and replaced the front wheel bearings and seals. I have everything on the way for a Tundra brake upgrade too, but I’ll probably wait until after the first test drive to minimize changes.
I didn’t like that the adapter plate had a mix of metric and standard hardware, nor did I like that the hardware that came with was not even high enough grade to be torqued to factory specs. So, I drilled out the mounting holes and used Time-Serts to adapt to all M12 hardware.
I also wanted to run flanged hardware, so I machined flats and clearanced the bellhousing where needed.
I had to find an M11x1.25 tap before I could install the flywheel as the adapter was a little crunchy and I wanted to make sure everything was properly torqued. With that I was able to install the flywheel and clutch to the engine for the first time.
This is a stock 22r clutch, so I’m guessing I’ll need to upgrade as soon as I add power to the tdi. It should do for now, though. I final test fit the bellhousing and better hardware.
The next time the motor goes in should be the last before first start, which is pretty exciting.
BimmerTim
Minneapolsota
ALH Tacoma
On to wiring. I really like to fully understand things, so I reverse engineered the tdi harness. I finished trimming and depinning what I didn’t need and am at the point where power and ground should be enough to start the engine.
I’ve also taken it to the next level by putting together full harness documentation, including pinouts for every plug and finding part numbers and vendors (DigiKey) for all of the connectors, pins, and seals.
I’m doing this mostly because the harness is old, has been flexed and messed with quite a lot, and essentially none of the wire runs are the correct length. So, instead of just cutting up and making this harness work, I’m planning to ultimately build my own brand new harness from scratch.
I have a lot of the final parts on the way right now, so I think the next update will be a pretty good one. We’ll see, though.
03Golfer
Canada
09 Jetta, 92 Toyota swap (ongoing), retired 03 golf
Very nice, I'd seen those half radiators and wondered if they would have enough cooling capacity for an application like this.
PickleRick
Greenville sc
The TDI motors are extremely efficient. The 2 core radiator on my 1st Gen 4 runner is extremely small. Even when temps approach 100 degrees the cooling fan never turns on without the AC button being pressed. My temp switch kicks on at 200 degrees and is wired where it could come on even when the engine is shut down. As far as I know it's never gotten hot enough to turn on.
BimmerTim
Minneapolsota
ALH Tacoma
Like PickleRick said, I think this will be good. The Civic radiator is wider than half the Tacoma rad and is twice the thickness, being a 4 core as opposed to the factory 2 core. I have an electric fan I'll be putting on as well with the OEM VW switch. We'll see, though!
PickleRick
Greenville sc
Keeping the egt in check on these heavier vehicles is about the only quirk of these I've found that needs close observation, but just under certain conditions. While normal driving rarely hits 600c I can push it past 650c if I have an extended heavy pedal while getting on an on-ramp to merge with highway traffic. The more the grade the quicker I can hit this point.
Id say this is an annoying feature but I have to watch the egt gauge on my 7.3 even more closely when towing my boat. Just part of diesel ownership.
BimmerTim
Minneapolsota
ALH Tacoma
@PickleRick What are you running for a turbo? I was hoping that with a turbo upgrade, but mild tune, the egts would stay in a better place and need less monitoring. Thoughts?
PickleRick
Greenville sc
I'm completely stock BHW, the Garrett has been replaced with a borg Warner direct replacement. No mpg, boost or noticable egt differences between the two. @burpod has mentioned he could likely help out my efficiency via tunes but I've either got the time or the money, never both at the same time to play with it more. Acme or maybe AMC cam (can't remember) Malone stage 2. Maf delete
At one time there was a site that sold turbos targeted to TDI conversion in yotas, slightly bigger. They advertised as less egt in a heavier swapped vehicle.
Honestly mine is fine my usage, when I finally get one tossed into the little lady's disco 2 at 5000lbs I may look to change things up.
The disco 2 adapters never seem to get built.
I am pickup up a factory solid axle Toyota pickup soon, depending on the shape of the frame ...there may be options on my horizon.
The lt230 doesn't play well with a 4l60 but plenty of Toyota mini truck cases have been bolted to the 4l60e and the stand alone controllers/TDI adapters are plentiful. If I can't find a clean 2nd gen 4 runner to frame swap I may see about putting yota 8" axles under the disco frame.
jmodge
Greenville, MI the winter water wonderland
More than I need, less than I want
That's a good idea. I should toss a dial indicator on it.
Look up the procedure, the opening of the bell housing is cast, can’t go by that. The trans has to be split to get to a doweled and machined bore to use as a centering reference. But It’s worth the piece of mind, in my opinion. You don’t appear to be too afraid of work though 😉
BimmerTim
Minneapolsota
ALH Tacoma
Lots of progress here.
I ordered a new shifter bushing a long time ago and decided to swap it out before I refill the trans. Glad I did, because it was GONE and bits fell into the trans when I pulled the shifter out.
I also added this little brace to the downpipe, wrapped the downpipe, and reinstalled for the last time.
Intercooler parts finally showed up to, so I got to work on that. The end tanks fit up perfectly.
End tanks welded on. I also welded up the corner seams and smoothed them out.
The inside has the deflector plates stitched in as well.
Then I added the inlet/outlet fittings and the port for the MAP sensor.
BimmerTim
Minneapolsota
ALH Tacoma
Radiator parts showed up too. This was a little more of a pain in the butt as I found a hole in the first radiator I was sent, so I had to order a second. That one was a bit better, so I cut the original end tanks off and test fit my redesigned end tanks.
Then end tanks get welded on. I’m not sure what the core material is, but it welded sooooo bad. When I pressure tested it I found so many pinhole leaks I needed to grind and re-weld.
The fittings are for a drain and a temp switch for the fan.
To mount the intercooler and radiator in the truck I also made this adapter bracket to mount to the OEM radiator mounting locations. I started by bolting all of the parts to a jig.
Once tacked together I can remove the jig, weld it out, and add fasteners.
I had to make the threaded standoffs for mounting the radiator and intercooler to the adapter bracket then weld them on. With those added I was able to mount the radiator and intercooler into the truck.
Now I was able to start planning intercooler hoses and radiator hoses.
Lower intercooler hose.
Upper intercooler hose and rad fan and shroud.
And here’s where we stand today. Intercooler totally plumbed. Radiator totally plumbed, pressure tested, and full system pressure tested.
Felipe_T4R
Detroit, Michigan
Soon to be TDI swapped 4Runner
Would you be willing to share some of the cad designs you used? I can't take 3d scans as much as I wish I could and I'd love to make mine half as clean as yours. If not could you point me toward a decent 3d scanner that won't kill me price-wise? I have access to Autodesk through school so I may be able to make something work!
BimmerTim
Minneapolsota
ALH Tacoma
Absolutely. What do you want specifically? The scans or the fab drawings?
BimmerTim
Minneapolsota
ALH Tacoma
A/C. We’re gonna keep it around.
I started by 3D scanning the side of the block, the A/C compressor, and the VW Passat A/C bracket. I tossed those into CAD and started messing around with mounting and tensioning options.
I ended up with an adapter bracket similar to what Jimbote had mentioned doing. Simply adapts the Tacoma compressor to the VW bracket.
Had the adapter plate made up at SendCutSend. To keep the threads from getting all messed up I inserted Timeserts to the mounting bosses.
Luckily it fit. So did the compressor…
I did have to sort out a different compressor fitting flange. The 4cyl and 6cyl Tacoma versions have the fittings on the side, which would get close to the frame and/or the boost pipe. I did extensive googlefu and found that a John Deere tractor uses the same compressor and the fitting flange discharges to the top with standard fittings. I ordered a few different fitting orientations and new high and low pressure line.
It all worked out pretty well, but getting the old fittings and line off of the Tacoma hard lines was a bit obnoxious, but it all worked out. I was able to pull vacuum and fill the system and it blows nice cold air.
BimmerTim
Minneapolsota
ALH Tacoma
Time to wrap up the power steering. Previously I had shown that I adapter the VW power steering pump and the steering rack to -6 AN.
I also used a BMW E30 power steering reservoir clamped to the oil filter housing with a bracket designed for E46 race cars.
The last bit to finalize was the power steering cooler. I was planning to use the Tacoma cooler, but I bent it. I also never replaced the frame brace that was ripped off by a deer, so I’ll get two birds stoned at once here. Into CAD!
I whipped up a u-shaped brace with some holes for air flow that a generic cooler fits in perfectly.
Got it made up at SendCutSend out of 1/8” chromoly and welded it onto the frame and the cooler fit mint.
Painted up the brace, final mounted the cooler and plumbed it in. Nice and low profile.
I made this super special tool to bleed the power steering without the engine running. It worked surprisingly well.
BimmerTim
Minneapolsota
ALH Tacoma
I need a throttle pedal, so let’s take a stab at it.
Like normal I 3D scanned the Tacoma floor in the cab and tossed it into CAD.
I loaned out my original mk4 pedal and the replacement I got back ended up being from a Euro A4 tdi. This turned out to be advantageous, because the pedal is removable from the sensor unit.
Adapting the sensor portion into the truck was fairly straightforward, except that the pivot point had to move up. This ended up not being a big deal, but it could have messed with pedal feel or placement or the ability to go to 100% throttle. This wasn’t the case here and it all worked out.
The adapter plate is just a simple plate with a very slight bent at one end that the pedal sensor bolts to and then the adapter bolts right into the truck.
There wasn’t a lot of room between the pivot shaft and the HVAC, so I had to bend the new rod in a kind of strange way. But the pedal placement and throw is perfect.
Potato
BimmerTim
Minneapolsota
ALH Tacoma
I should probably figure out the fuel system and maybe not keep running it on a Gatorade bottle filled with diesel and Marvel Mystery Oil…
As you can see in the prior picture and this one, I made a little mounting bracket for the OG mk4 fuel filter to sit in the engine bay.
On the tank side I started by using my engine hoist to pull the box and toper all in one.
That’s a lot of rust…
I didn’t take pictures, because it was so frustrating to have bought this in Seattle, didn’t drive it in winter, and still have this much rust. Even if it was mostly surface rust. In any case, for the frame I wire wheeled and sanded all of the rust off the frame behind the cab. I then used Ospho rust converter, which turns iron oxide to iron sulfate. Then a coat of Eastwood rust encapsulator. Topped off with semi-gloss black and satin clear.
The back of the cab was even more disappointing. As I was scraping and removing all of the loose rust I found the seam sealer just peeling off in large sections exposing what appeared to be hand grinding/sanding marks and bare metal. Red Flag! A little more inspection and pulling the rear interior out it became pretty clear that the rear panel had bee replaced, poorly, some years ago…
I had previously pulled the rear trim out to add some sound deadening and paid no mind at the time, but here you can see that the rear panel is all black, where the adjacent panels are grey. This is telltale that the black panel is a replacement.
While I was in there I added a layer of tar sound deadener and a foam layer over the top inside both of the extended cab pockets behind the speakers.
In my frustration I did not take pictures of repairing the rear of the cab, but the process was similar to the frame, with the exception of adding seam sealer between the rust encapsulator and black paint. I also used gloss black and a 2-part 2k clear. You can’t see this seam with the box on, so I wasn’t super concerned with blending or anything, but now it should keep it from rusting again.
Before pulling the fuel sending unit I jumpered the fuel pump and pumped all of the remaining gas into my daily. With the sending unit out I spent a decent amount of time getting the last bit of gas out, cleaning up any debris, and drying the tank out before dumping in a few gallons of diesel.
I removed the fuel pump from the fuel sending unit and just added a bit of submersible fuel line to reach the bottom of the tank.
To get the diesel pump nozzle to fit I had to make the filler whole a bit larger. The flap does fit quite right anymore, but it really doesn’t matter.
I lastly ordered a green diesel fuel cap to remind myself…
BimmerTim
Minneapolsota
ALH Tacoma
Box and topper back on without much drama it was time to wrap up the wiring. I started in the engine bay. You’ve seen the chaos pics of the wiring all over the place, but I took the wiring from each sensor on the trans and engine and heat shrink loomed it and labeled it. Where there were loom joints I used adhesive heat shrink to keep it as water tight as I could.
I routed everything around and up through the factory boot on the firewall. I used silicone/fiberglass heat sleeving behind the head, but that is about the only place.
On the inside I mounted the VW ecu in the same place as the OG ecu. I also did a TON of research all over and found new pins and seals for every plug on the VW and Toyota harnesses, so I was able to cut and re-pin every wire so they are perfect length. It was also so painful and tedious.
There is only one spot where the VW and Toyota interface, and it’s called the IK2 plug, located just above the glovebox. I did use three of the VW colored body plugs to have a termination near the ECU for the throttle pedal, cruise control, and the 109 relay.
I do still have a few things with wiring to finish and tidy. I ran new wires for the glow plug relay from the ecu out to the Toyota fuse box under the hood, but I haven’t terminated them at either end yet. I’m planning to use an unused fuse in the Toyota fuse box for the glow plugs as well. I need to make new ground cables. I also need to actually get the cruise working. Lastly, I just need to wrap the wiring in the cabin with the VW cloth tape to prevent chaffing.
One odd thing I found was that the VW and Toyota oil pressure switches are opposite. The Toyota switch is what you would think; no pressure, the switch close to ground, light comes on. VW, however, added some logic about not throwing the oil pressure light if not running and/or under 2000 rpm, so the switch is normally open and closes to ground when there is oil pressure. So, currently my oil pressure light is on while driving. I have an adapter to put the Toyota switch in place of the VW one.
Otherwise, it’s done for all intents and purposes. I’ve been driving it for about the last two weeks or so and have put nearly 300 miles on it. There is some maintenance stuff to do to the engine now that it runs and drives as well. The injection pump is loud and the nozzles have 278k miles on them, so I’m nearly certain it has to do with that. I’ll be doing a timing belt shortly, but that will entail finding a way to find TDC, since I don’t have a factory flywheel or marks. I also want to inspect the cam condition to see if I should replace it while I have the timing apart.
Once it’s good and reliable I do plan to upgrade the turbo, injectors, and a tune. I will have a permanent CEL until I do a tune since I deleted the EGR and ASV. I don’t currently have any other codes, which is pretty amazing.
If you have any questions or want to see pics of anything specific, let me know.
