Bear
- Joined
- Jun 23, 2003
- Location
- Westminster, Maryland
- TDI
- Golf GL 2 dr 2003 Mojave Beige, ESP, CWP, Monsoon, 2003.5 console
I hate mentioning it its like tempting fate. But, it does happen. I am wondering what the first response to it might be. First, it would seem that the first step would be to rotate the crank and cam by hand in sync and then check compression (or leakdown) to see if the head and valves are OK. If they are, then the motor would be good to go? That way, you could avoid taking the head off. Or is this too much wishful thinking and should you just count on, at least, a few bent valves. Moving on, if the valves are bent, then can the head be re-used if the valve seats are visually OK?
