Thom
Wondering where and how those of you who have added upgrades that talk to the CAN bus have made the connection. Since it's twisted pair and is capable of data speeds up to 1 Mb/s, I'm assuming a copule wire taps and some 22 gauge wire isn't the way to go?
http://www.can-cia.de/can has the following info:
A connector used to plug devices to the bus line shall have nominal impedance of 120 Ohm and a nominal transmission resistance of 70 mOhm. The cables chosen for the CAN bus lines shall have a nominal impedance of 120 Ohm, a length-related resistance of 70 mOhm/m, and a specific line delay of nominal 5 ns/m. At bus line length greater than 40 m, the specific resistance of the bus cable should be lower. The aim of these specifications is to standardize the electrical characteristics and not to specify mechanical and material parameters of the connectors respectively cables. The bus wires may be routed parallel, twisted and/or shielded, depending on EMC requirements.
