Tandem pump question
Dimitri16V
DE
01 Golf, 04 Golf
is the vacuum outlet supposed to spin freely ?
I experience sporadic loss of power brakes and everything else checks OK
Jettascuba
South Africa
2002 VW Jetta
Yes, it is supposed to 'spin' freely. Check the connection just aft of the vacuum pump - in fact check all the connections. These pipes do tend to crack at the connections. If you wonder about the vacuum pump, remove the vacuum line at the y-connection just beyond the intake manifold and feel, listen for vacuum while the engine is running. This is the line that is also plumbed into the brake vacuum line.
jasonTDI
TDI GURU Vendor , w/Business number
Oregon, WI
12' RAM 2500 QC,LB. 2019 Cherokee 2.0T
With 205K it wouldn't surprise me if it were going out. I'd replace it, the next bit to fail will be the shaft seal and that'll flood the engine with pressurized diesel.
Dimitri16V
DE
01 Golf, 04 Golf
Actually 351K miles
i will run some vacuum tests in the weekend
Mako
Cape Town
AMFPolo 1.4 TDI 100%Biodiesel, AHF Golf TDI 100% Biodiesel, AHF Golf TDI Wagon 100% Biodiesel, VW Syncro 3CT Kombi 100% Biodiesel, Corsa 1.7D 100% Biodiesel
Vacuum spigot connection should not spin freely and will loose vacuum. Easily repaired with epoxy.
Dimitri16V
DE
01 Golf, 04 Golf
you are correct
Perfect timing I read this , just got done troubleshooting it
I put a vacuum gauge , pumped the brake booster down thru the hose with the one way valve , vacuum was leaking slowly . Discovered hose has a crack in the bend
put some tape to seal it , hooked up a vacuum gauge on the T in that hose , pumped the booster down , vacuum holds
reconnected everything . started the car , vacuum built up slowly to -1000 mbar. Tandem pump outlet is wobbly , moving around makes vacuum drops to -500mbar
also noticed oil in the vacuum outlet .lately I had excessive oil consumption , I think the vacuum pump has been sucking air thru the wobbly outlet and pressurizing the crank case sending more oil thru the PCV
now who has the best prices for a tandem pump and booster vacuum hose ? the epoxy might work but at 350K miles , I am sure the fuel part of the pump has to have some wear
Fasteddie10
Illinois
2004 Jetta Wagon TDI, 2-2005 Passat Wagon TDIs, 2-2004 Passat Wagon TDIs
Tandem Pump
My 2004 Passat had intermittent issues with the turbo boost. I found the vacuum supply varying from 19 inHg Vac to 10 inHg Vac. Found the tandem pump nipple loose and wobbly. This pump is the LUK and the nipple looks like it was pressed in and I did not see a way to fix it other than glue. My 2005 Passat has the Bosch pump, the nipple is screwed in on this pump, you can see the hex head on the nipple base. The output of the 2005 pump is 25 inHg Vac and steady.
So found a new Bosch Tandem pump on eBay for $250. This pump puts out the 25 inHg Vac. Works great now!
drehenkraft
Tempe, AZ
2005 Passat TDI GLS Stonehenge Grey/Grey
metalmanparts.com $290 shipped. Just got mine, debating self-install vs my local indy shop.
jasonTDI
Oregon, WI
Passat is a PITA due to tight confines. You can do it though with some patience.
