I have a PD150 that seems to be suffering from lack of fueling, lift pump pressure is fine and the car starts on the button and idles well but the throttle response is terrible and will hardly pull itself along.
So far i have checked:
Cam timing,
lift pump,
MAF,
MAP,
Filter,
Turbo,
Exhaust system,
Injector settings,
Camshaft.
The spec for the tandem pump is 7.5 bar at 4000 rpm which the pump will produce but at low rpm the needle on the gauge bounces around so much it bent the needle on my very expensive Sykes pressure gauge.
Has anyone tested pump pressure and what did you see or is there anything i am over looking.
Any suggestions gratefully recieved as i am running out of ideas !!!
Cam timing,
lift pump,
MAF,
MAP,
Filter,
Turbo,
Exhaust system,
Injector settings,
Camshaft.
