choij1
- Joined
- Feb 27, 2001
- Location
- Markham, ON
What do you think of 205/75-15 on the stock steel rim, instead of 195/65-15?
Advantages I can think of:
a. equivalent to having wider 1st gear
b. equivalent to having taller 5th gear (plus on MPG)
c. 1” more ground clearance - less chance of having a cracked belly pan
Disadvantages I can think of:
a. Less power – Upsoluting becomes a must?
b. wider tire – more tire resistance (minus on MPG) I wish I could find 195/75-15
c. more air turbulence under the car – more air drag (another minus on MPG)
d. 10% speedometer error – ABS might work funny (would speedo recalibration help?)
e. 1” clearance is required around the wheel - might need stiffer springs
f. taller tire and higher center of gravity – worse handling
I always had this idea, believing it must be the cheapest way to improve MPG and adding 1” ground clearance. But now I think it might not improve fuel efficiency at all. Still, the 1" part sounds sweet to me. What do you all think? Jin.
