no_one_of_consequence
I have a few questions with this mod, but anyways it’s done.
I changed the rear tires with taller ones. The swap was: Michelin Hydroedge 205 65 R16 T94 instead of Michelin Pilot HX MXM 205 55 ZR16.
I needed to replace one tire but the cost of the Pilot was TWICE as much as the Hydroedge. Then I remembered that gdr703 suggested that "if the car is encouraged to sit with a nose down tail up attitude, by adjusting weight distribution, or suspension, this will help reduce the underbody drag". So I went for the tallest tires available for the width (205) and rim (16) classes.
I still have to find out if this tire fits in the forward position, but if this configuration yields better MPG then I will keep the 205 55 R16 size in the front.
Another question is the rotation. The best I can figure out is to dismount-mount (because the hydroedge is directional) and rotate left to right both sets (front and rear). The alternative is no rotation.
The diameter of the Pilots are 642 mm and the Hydroedge are 668 mm the difference is 1.026 inches. This means 19 rotations less per kilometer. Now this will influence the speedo or the trip meters? My guess is no considering that the taller tires are not at the front.
Any thoughts?
Any thoughts?
