funoutdoors121
Hi All;
I am thinking of trying to swap the bottom rear seat of a 2015 GSW with the ones from a 2009 TDI Jetta SportWagon.
The ones from the 2009 lift up and allow the upper rear backseats to lay flush or one can put a heavy load directly on the metal subframe instead of on the lower rear seats.
Has anyone looked into this, or tried to remove the 2015 bottom rear seats?
The 2009 bottom rear seats come off very easily as they pivot on metal hinges that can be squeezed to remove them from the small welded mounts that could be easily added to a 2015 once the bottom rear seats are removed, if the bottom metal frame has the same shape as the 2009.
Any thoughts/feedback/suggestions?
Thanks!
Thanks!
