Thorgs
Now the SRS/Air-Bag light is constantly on on the center console. Is there a fuse or relay I can pull to shut it off?
is there a way to put a jumper wire across the old airbag plug? make the car "think" the bag is still there?
Well it turns out the part I ordered was 3A0919235P but Jim Ellis VW Parts website lists them as the same. Maybe they did away with 3A0919235M and only make the 3 bulb warning lamp.Is 3A0919235P the same thing as 3A0919235M?
That's interesting. What's the difference? Do the inertia reels in the pre-tensioner belts allow a bit more travel before they lock than the non pre-tensioner belts, or what?compu brings up a good point, you may want to get some non-pretensioner seat belts to go along with the lack of airbags, as those type are designed to be used without SRS.
I know about pretensioners but I thought on these early models they were triggered by their own propreitary g-sensors, independent of the SRS sensors
I will say that my seatbelts in my 1997 A3 seem to have pretensioners. I have triggered it before sometimes just by moving forward too suddenly. I have also crash tested my airbags before, unfortunately, and they HURT! Like being punched in the face. Also got burned on the arm by the explosive trigger chemical and the car stunk for about a week. That sucked! Was a pain trying to replace all those parts but part outs are your friend there .
No. As mentioned "P" is for ABS equipped cars and has 3 bulbs.Is 3A0919235P the same thing as 3A0919235M?
Sounds like someone swapped a 2 bulb lens on a 3 bulb housing.Off-topic but does anyone have the console light with just airbag/brake? That's the one I have but there's 3 lights behind it and I think it was meant for the airbag/brake/abs...or maybe VW was just cheap and put 3 bulbs in all of them. It just looks weird because when my e-brake is pulled, only half the word "brake" is lit and when the airbag light is on, only half the icon is lit.
Sounds too easy and it didn't work for me. I checked the Bentley and It's the correct plug, but my bulb remained on.Thorgs, I still don't know why you don't just unplug the two pin connector (brown /green and black / red wires) from the back of the lamp cluster....
