Suspension upgrades
Andyinchville1
Virginia
2003 Jetta TDI wagon, 5 sp, 226K miles
Assuming the suspension is OK in stock condition (not worn out / sloppy) .....I would start with a rear anti sway bar
If some of your suspension needs work .... fix that first .... getting performance parts for whatever is being replaced.
You can refer to my signature for what I have done (most of the parts were added on as stock parts wore out and / or needed replacing .... some were added IF it made sense while things were apart and would have been difficult to take everything back apart to change something simple).
After the rear sway bar (and bushing if needed), I would do the struts and change the front springs and get better strut mounts (I added a 1" spacer while I was in there to run bigger tires when the old ones wore out ... knowing what I know now I should have gone 2" with the spacers but maybe in the future (I'm thinking lightweight lithium battery / carbon fiber hood may loose enough weight to get the 1" for "free"..... the lightweight mods are on my to do / wish list).
The skid plate does noticeably stiffen the front end ..... extra bonus it protects the oil pan.
I would LOVE to hear a review of some of the suspension goodies from here :
They have other goodies also ..... I'd love to try some!
Andrew
J_dude
SK Canada
2003 1.9l “Jedi”
South of Boston
What people mention here: Good dampers and tires will make a world of difference. Fresh control arm and rear axle bushings would help, too, if they're worn (and they probably are).
jettaroundtown
sacramento
Thanks for the input, folks!!
I'm going to replace inner, outer tie rod ends.
New shocks and all the bushings.
Any recommendations for the shocks? I am looking for a smooth freeway suspension.
South of Boston
My favorite is Koni Special Actives. If you want to spend less, the OE Sachs dampers work well.
chaoscreature
vista, ca
2006 Jetta TDI Special Edition
"best bang for the buck suspension upgrades?"
My first question when someone asks this is always: What do you want to improve? Ride Quality, turn-in, corner exit oversteer?
I guess my point is there is no single answer to this question and like most things in life, suspension upgrades almost always involve some amount of compromise.
braddies
America
03 golf ALH
How many bucks? Full front end from an mk1Audi TT makes a dramatic difference. Subframe, control arms, sway bar, spindles, struts, 1.8t calipers/rotors for small rims, TT calipers/rotors if you're running 17 or 18" wheels
Zak99b5
Albany NY
2003 Jetta TDI
I assume you mean upgrade the performance of the suspension, not looking for "stance" or other bs. In order of importance:
1. Replace all worn suspension bits
1a. High performance driver ed training session
2. Sticky tires on light wheels, such as the Avus
3. RSB
4. Better dampers than stock (I like Koni Yellows)
5. Stiffer springs that do not lower more than 1/2" if at all (I like Neuspeed SofSports, but H&R OE sport are good too)
