mpgomatic, Something to think about....
Weight is divided into sprung and unsprung.
Simply put, if you replace one fender with a carbon fiber duplicate, and save 2 lbs., you're good to go. BUT........
If you change one steel rim for an alloy one, and save 2 lbs. of weight, the actual vehicle weight savings is tripled to 6 lbs. Not to mention any resulting suspension performance gain.
Aero gains at legal(?) highway speeds, are a bit harder to perform. You don't state what body style you'll be using, so that makes suggestions harder.
First thing on the agenda will be frontal area. Lowering car reduces frontal area, so will narrower tires. Moon discs on all rims work real good in smothing turbulance around wheels. Another area to investigate is turbulance inside the wheel wells, as the spinning tires create a lot of that. Try to maintain a level attitude when lowering, as a nose down(raked) vehicle looks neat, but defeats your purpose. To prove this, ride down the road at 60mph, with your hand out the window, facing the front. Keep it level and note the amount of resistance that position is developing. Slowly lower the front(leading edge) of your hand and note what happens. Surprise, very little drop goes a long way !
Look at the vehicle from the front, including underneath and on the top. If it sticks out.... take it off ! Roof rack-mirrors-antennas-front tag frame(cause in Joisey you have them)... plug/fill in driving/fog light openings, etc.
This should keep you busy over this hot weekend, enjoy!
I hope this helps, as i'm new to this forum, and this is my first post.
Which swamp in Jersey are you referring to, as we have many :>) i'm down south, across from Philly.
Alan
