Sunroof Stuck Open on SE
PHOTOGUY1000
Canyon Lake, CA
2015 Golf S, SE & SEL
Sunroof is stuck open on my 2015 golf se... has anyone replaced the motor? I have not found any info on the job? Location of motor?
Steve
sootchucker
Colorado
2015 Golf
this sounds terrible, probably involves headliner removal which cant be fun.
i thought there was a way to manually close the sunroof via a tool.
Nuje
Island near Vancouver
ON the older cars, there was a manual crank that you could access under a little panel behind the dome lights. (And also where the motor was, making replacement fairly easy).
Pop that off and see if you have anything there.
PHOTOGUY1000
Canyon Lake, CA
From what I read their is no manual way to close it... I replaced the sunroof in my mk3 it was easy. I cant even find a tutorial on pulling the headliner. Dealer wants $1200.
ticaf
US Mid-Atlantic
Stock 2015 Golf SW S Manual TDI
It could be some software protection. Any obd codes? (VCDS or obd11).
You could try unplugging the battery, wait a few minutes (or try starting the car), and plug back.
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
Switch could also be culprit as motors are pretty robust. roof is probably made by webesto. If the motor is jammed, Thumping on the glass firmly while pulsing the switch may free it up.
smittyatl
Atlanta, GA
GSW
Had my pano roof stuck in the tilted open position. Took it to the dealer and they said it worked after "resetting it". Maybe try disconnecting the battery and trying again after reconnecting?
1854sailor
Resident Curmudgeon
Westerly, RI
Probably "reset" it with a rubber mallet...:D
