gdunn
- Joined
- May 12, 2003
- Location
- Hillsdale, Ontario
- TDI
- Golf, 2k, Green, Auto: Jetta 2003, Black, Manual
On my 2003 Jetta Wagon, the sunroof will open (tilt open--not slide open) for no apparent reason. It tilts about 1/2 way open, not fully. There doesn't seem to be any rhyme or reason behind it. I'll be driving along and notice the motor opening it and an increase in noise. Sometimes it'll close itself, sometime it won't. The switch is in the closed position while it's doing this.
I can exercise the switch and it will work (opens and closes fully). BUT, (I'm sure this is important, I just don't know how): I have to close the window by moving the turn switch ssslllooowwwlllyyy. If I just turn it to the closed position (quickly) the sun roof will start to tilt down, but hit the 1/2 way point and then open up again. If I go slowly, it'll fully close.
The window has never leaked and the drain is draining.
Any ideas on what's wrong and how to fix it? It seems to me to be a switch/sensor problem, but I haven't been able to dig up much information on the inner workings of the sunroof in these cars.
Thanks in advance for any info!
