hangman
I’m getting water in both front carpet and the driver’s side rear. I’ve pulled away all the trim to access all 4 sunroof drains.
i’ve cleaned them out periodically with a weed trimmer line. These things were designed very poorly! The hoses barely fit in those rubber connectors. I cut that tapered end off the rear drivers rubber plug. That’s the part that gets clogged. The hose came out again!
I know that the rear ones drain out through the wheel well. Where do the front ones exit? They eventually exit in the wheel wells? Or do they exit in the plastic grill underneath the wiper arms? Because I’m trying to figure out if I need to cut the end of that rubber plug (the part that clogged).
I was thinking of getting a plastic Barb and putting it inside the existing drain hose and adding a couple extra inches in length. Then use some some small hose clamps to hold it in place.
This way it will go into that rubber connector firmly. Will probably put gorilla tape around the connection..
how have you fellas fixed the drain hoses?
2013 JSW
thanks
2013 JSW
thanks
