OnePutt
- Joined
- May 21, 2007
- Location
- The burbs of NorCal
- TDI
- 2001 Golf (Silver) | 2005 Jetta Wagon (Spice Red)
I have a knack for buying cars with bad transmissions...maybe its a sign that I should just stop buying Automatic POSs...
2001 Golf TDI - O1M...'nuff said...swapped out to an 02M
2002 Acura TL-S - Tranny replaced 24k, 56k, 137k
2005 Jetta TDI Wagon Automatic Tiptronic - Feels like the transmission is slipping...
This is on my Jetta
Reverse works fine, put when I put it into Drive, press the diesel pedal I get anything from:
1. 1'st gear hesitates for a split second then catches and goes
2. Accelerate slowly, and everything works OK. The transmission switches between gears fine.
3. Accelerate quickly and all kinds of funny stuff happens. The transmission doesn't shift smoothly between gears. My RPM's surge between gears, I assume because I'm telling the car more fuel...go faster!, but the car isn't in gear, so the RPM's just surge. After a split second RPM surge, the transmission slips into gear and everything is good. This only really happens between 1'st to 2'nd and 2'nd to 3'rd.
Car is tuned RC2+ with VNT17, EJ SMIC,
Anyways...I don't have any idea how this stuff works. Any help in diagnosing this is much appreciated. Here's the vag-com scan results of my transmission read:
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 BL
Component: AG5 Getriebe 09A 0262
VCID: 76ED177A52DC1C9
2 Faults Found:
00300 - Transmission Fluid Temp. Sensor (G93)
27-10 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
28-10 - Short to Plus - Intermittent
Thanks for reading...and helping. Maybe I have another 6 speed in my future...money is tight right now...I really don't need this.
This is on my Jetta
2 Faults Found:
