MacAndrew_Jack
Hey TDIers,
I have an ALH that I drove 500 miles last weekend, and started in cold mountain weather over several days, no problem. I drove home after all that, and now it is slow cranking on startup, not starting. When I charged the battery with a trickle charger, it started. So it seems to be the battery, but why would it suddenly fail like that? The VLT reading on Scanguage says 12.0 at rest then 14.1 when running. A voltmeter directly to the battery read 12V, before the charging.
Could I be missing something else?
The battery is less than a year old, and has been bomber the whole time.
I was driving with 150w aux lights, as I usually do. At some point on the last drive home before the problem began, I noticed a smell of what I thought was the marinara sauce from our takeout (tasty fried mac and cheese balls with marinara dipping sauce from Endo's grill in Copper, CO). It isn't going away easily in the cabin and I wonder if it is van related, but I can't find where it is coming from if not the actual marinara sauce, now removed. I smelled in both battery compartments and the smell is not coming from there. Is this a red (marinara) herring or could there be a marinara version of electrical smell indicating a short that is draining the battery? I don't smell any typical electrical smells.
Or is the simplest explanation (battery suddenly not holding a charge) applicable.
Thanks in advance.
-macjack
Thanks in advance.
-macjack
