Highwaylizard
2014 Jetta Sportwagon 6M TDI with 193,499 miles. Daily driver and only vehicle. No codes outside of P2004, P2006, and P2015.
The Symptoms
Really at a loss here as to what could be causing all of this. I am planning to take the airbox tube off that feeds the turbo and see if the spool is loose/damaged/seized so that I can rule that out. I also think I should pull the hoses off the intercooler and make sure there isn't fluid in there.
Any suggestions, observations, or feedback would be most gratefully appreciated.
The Symptoms
While waiting in line at the car wash my temperature spiked to 204. Coolant temperatures never go this high unless I’m doing a regen. Temperatures did go back down once I entered the carwash. Perhaps water on the radiator helped bring temperatures back to normal. To be clear the car was not doing a regen.
Running cold on highway – temperature as low as 161 but typically now at 172-179. It takes longer than normal for the car to reach these temperatures. Normally the temperature is pegged at 191 degrees. I drive roughly an hour each way to work so the route and driving conditions are the same everyday.
Constant regens while driving that only take the coolant temperature to 190-191. Can hear fans running and smell that “special” regen odor.
Engine clatter is now very pronounced whereas before the engine was relatively quiet. Very noticeable during acceleration. It's almost a rattle.
Poor tank average mileage. Dropped from 42 MPG tank average to 32 MPG tank average over the past two tanks.
Overall lack of power. Several times while accelerating the power has kicked in very sharply at 2200 RPM.
Violent engine jerking at 1700 RPM (third gear and roughly 30 MPH) especially when hold this speed.
Even when holding steady speed on level ground instant MPG is lousy.
Rough idle almost as if it is missing.
Chatter at idle.
Faint smell (possibly of burning oil?) from time to time but not always.
No visual evidence of cross-contamination between the oil and coolant. Both fluid levels seem unchanged.
Timing belt, water pump and thermostat replaced November of 2022 at 159,522 miles.
Extended crank no start followed by very rough idle.
Possible Causes
Turbo on the way out?
Crankshaft position sensor?
Thermostat bad?
Clogged injector?
