oldpoopie
- Joined
- May 14, 2001
- Location
- Sheridan Oregon
- TDI
- 2001 golf gl, 1981 ALH swapped rabbit pickup, 1998 beetle, 2003 jetta wagon, 2002 jetta wagon BEW swapped, 2001 Audi TT
Well, today started out nicely. Beautiful weather, and a nice day planned doing maintance on my tdi. I had planned on replacing the passenger front wheelbearing, both ball joints, and the a-arm rubber bushings with poly ones. I should have known something was happening when the ball-joints didnt show up. Anyway, I proceeded to remove the drivers side a-arm. It was pretty easy, and I pressed in new eurethane bushings that were significantly stiffer. I then tried to remove the passenger side a-arm. There are 2 bolts. One that threads vertically with a nut on the top, and the other that threads horozontally with a captive nut within the a-arm. I removed the vertical one with no problem. Then I went to remove the horozontal one and it just spun and spun. I soon realized that there was no way for me to stop the nut from spinning with the subframe in-situ, so I removed it. Upon removal I realized that there was no repairing it without cutting the subframe open. Luckily I have a friend who is an excellent welder. Timing was good there and he was home when I called. We took the subframe to his shop where we cut a panel open in the subframe, tacked the nut in place, and closed the panel back up again. The nut looks like it was never tacked in the first place, and that it came loose on its own. At any rate, here are some pics. I dont have a pic of the finished piece unfortunately.
access panel cut
Access panel heated
bent back, nut visable.
Nut removed, no evidence of old tack weld
nut, also no evidence of old tack weld
And finally the nut welded in place, to never come off again.
I forgot to get shots of the "hatch" welded shut again. I'll try and do that tomorrow. It looks pretty good and I think will be plenty strong.
After I got in the accident a year ago, they replaced the a-arm on that side. I think when they did so, they tightened the nut down too much, and it broke free of whatever was holding it in place. At least now I wont have to worry.
access panel cut
Access panel heated
