richmondvatdi
- Joined
- Feb 5, 2005
- Location
- Chesterfield, Virginia
- TDI
- 2005 Passat Wagon 5-speed,2003 Jetta GL Wagon, 2003 Jetta GLS Wagon, 2013 CC 2.0T
I'm planning to change the subframe bushings in my B5.5 wagon, and I am trying to figure out which ones I need. The auto was swapped to a 5-speed by the PO. I believe the auto trans uses the same p/n for all four of the bushings (p/n 8D0 399 415 D). However, from the parts diagram it looks like the manual transmissions may use a different p/n for the rear bushings (8D0 399 419 E). I tried ordering the 419 but apparently it has been discontinued by VW (or may not be available in the US). Can anyone shed any light on this? Since this is my DD, I need to be sure to have the correct parts on hand when I start removing the old bushings or else I'll be walking to work (23 miles each way).
