clyde
- Joined
- Apr 8, 2000
- Location
- confluence, Snake/Clearwater
- TDI
- 1998 Jetta, 1959 DeSoto with leopard-skin seat covers
It's almost stuck.
Removed other three GPs. At first try, this one turned only about 15 degrees. I blew debris out, appled WD-40. Later it turned a little more. Maybe 30 degrees.
Don't want to break it, so I apply more WD-40, and let it set overnight.
Next day, it turns a little more.
But still seems to "hit the wall"—a spot where it's so tight that I know it will break if I pull on it.
After four days it still hasn't turned more than 270 degrees—less than one full turn.
If it were in the car, running the engine would heat the head and maybe help free the plug. But the engine is out of the car.
One way to loosen the glow plug would be to freeze the plug and heat the head simultaneously, but that's tough.
Ideas? Suggestions?
Ideas? Suggestions?
