TDINJ
About 4 months ago I had my rear brake pads replaced. At the time, the right (passenger side) rear wheel brake made a horrible noise. Turns out the caliper was stuck. They replaced the caliper on that side as well as the pads and I think the rotors.
Fast forward to now, It's beginning to make the same noise again, sort of like what it sounds like when you have a "ringing in your head" during a headache, or when you rub your finger around the top of a wine glass.
I'm wondering if the caliper pins are stuck and if they weren't probably lubed during reinstallation. I had this happen before in the past a few years ago.
I'm not good with brakes, but am wondering if I can easily lube the two caliper pins on the brake assembly without taking too much apart or messing up the brake assembly.
Thanks.
Thanks.
