snakeye
I'm trying to assemble my new struts, for which I got some Powerflex poly mounts. Curious if anyone else has run into the problem I'm having: as soon as I tighten the bottom nut, the whole thing just binds and the mount doesn't spin at all. I noticed the plate in the mount if very thick. Here's a pic:
Here's the nut sitting inside of the mount:
It's hard to see, but the bottom of the nut doesn't clear the plate. I suspect this is what's causing my problem. I think the nut is supposed to tighten against the top of the bearing, and loosely hold the mount in place. Instead, it's pulling the whole mount down, essentially joining together the shaft, bearing, and mount. Do I have this right?
