Strange Water Temp with Scangauge II
diesel_dog
Jenkintown, Pa.
I have had a 99.5 golf for about a year and never had any problems with the water temp that I could tell. The idiot gauge points at 190 when warmed up as if it was nailed in place.
However I recently bough a scangauge and have one of the gauges set for water temp. Normally it reads between 180 - 190 however I have noticed some strange behavior recently. At times the scangauge temp will start to climb slowly. It seems to keep climbing up into the 250's while the idiot gauge says 190. What is really strange is that each time the scangauge updates the temp I can see that it first flashes a temp of around 185 for about a quarter second then goes to the higher number. Could the engine take that kind of temps without melting?
Am I dealing with a bad scangauge or a short? I do have a new temp sending unit but I dont really believe that is the problem.
Mark
c170b
Mid-Michigan
05 Jetta
Mark
I have a scangauge also: water temp on mine takes a long to come up. the gauge on the dash is like yours peged at 190.
mine just takes a long time to come up to temp...????? Scott
stancho
Schaumburg, IL
2002 Jetta GLS
Yeah, there is temp band within which the dashboard gauge shows 190. I've seen the water temp as high as 225 on my car. Maybe some of the more experienced voices will chime in as to what the normal operating temp range is.
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
2001 Jetta w/ScanGauge I have never seen the temp over 185 and it was hot (mid 90F) this last month, but I drive rather conservatively. Anyways, dash temp gauge has a very "general" reading. (many describe it as a glorified idiot light) Mine will stay glued at 190 after warming up virtually no matter what. In fact, the dash gauge gets to 190 while ScanGauge is still climbing 170+ on the way to 181 where mine spends 99% of its time. I'm sure the gauge will give you a good general idea of whether the engine is cold, warm, operating temp, or HOT-but I wouldn't pay too much attention to the degree numbers on it. Scangauge may read temp from a different sensor than the dash, I do not know.
Phred
Fort Collins, CO
2005 Golf
I noted the same behaviour on my 2005 Golf. While the dash indicator stayed pegged at 190F, during a hard climb in very hot weather, the ScanGaugeII read up to 205F, and backed down when I was done loading the engine.
My guess is that the ScanGaugeII is reading a more accurate tempurature that fluctuates with load, and the Dashboard gives a "normal" reading (midpoint at 190F) until things start getting really hot.
Interesting design descision by VW...
points
Northern Twin Cities, MN
2003 Jetta
When I got the SGII my temp was reading 220-235. I knew something was wrong so I replaced the thermostat and the temp is at 202-205. The stock temp gauge is a joke.
Matthew_S
Renton/Redmond, WA
2002 Jetta GLS galactic blue
The temperature gauge will read 190 from approximately 170 to something just over 200 (220 maybe). Basically the gauge will show 190 when the engine is at normal operating temperature. VW knows that we can't handle the truth:rolleyes:
250 is way too hot. Try to get a different scanner (VAG-COM preferably) and see what it tells you.
phil B
Fairmont Hot Springs B.C.Canada
mkiv wagon
I Have a SG that reads high, and the dash gauge stays at 90°. The SG initially read 190°F,until the main(large)fan failed and was replaced. I've replaced the thermostat and temp. sensor. In the process of replacing the radiator temp sensor,and having my doubts. I've even unplugged and cleaned the plugs on the car and the ScanGauge. This issue is on a VW MKIV JETTA TDI WAGON.
Nuje
Island near Vancouver
How high is "high"?
(You might want to stay consistent with your units, too - 90°C....what is the scan gauge reading in °C?)
For anyone interested in how/why the cluster shows 90°C / 190°F pretty much no matter what, here's a good explanation (and solution):
phil B
mkiv wagon
I stand corrected,the thermal switch was changed yesterday.
The original temperature gauge on the cluster 'used' to take its time rising to 90°C. Now it definitely rises much quicker to 90°C and stays there.The SG temperature is in Fahrenheit. Will change it to Celsius tomorrow.
Thanks in advance.
Tuheeden
North Carolina
2013 & 2014 Jetta sportwagon
The idiot temp gauge will show 190f when the engine reaches low operating temperature of 167f. I have never seen the gauge show more even with coolant temperates above 235f.
Normal temperature is 185 to 210f but up to 220f under load is pretty common. If it's going above those numbers or below those numbers, I always change the thermostat and waalaa things go back to normal
