macmatic
1. The problem.
2. What I've tried
3. A little backstory
I have read... quite a few MK4 brake threads in the last couple of days.
With the engine OFF the brake pedal is good but not perfect. But also not anything I would question if that was the extent of the problem, I can't even rule out a little flex in worn slide pins causing what movement there is. I've felt similar play in motorcycle brakes with worn pins or bushings. It will move through the first 20-25% of the travel with fair resistance and then gets too hard to push further. I can keep pressing HARD for at least a minute and not feel any further movement.
As soon as the engine is running the pedal is totally different, very soft in the first 2/3 of travel and then feels about the way the first part of pedal travel feels when the engine is off but does not bottom out. Given that the pedal doesn't bleed down under very hard consistent pressure with the engine off I don't THINK the master cylinder a problem. There are no external fluid leaks. Front calipers are free, I have not retracted the rear pistons but the slides are free.
I have a parts car that also "stopped when parked" and the pedal is nice and firm on that from the start but I don't really want to start swapping parts in chasing what may be just a stubborn air bubble.
So far I have:
Gravity bled the brakes.
Pressure bled the brakes.
Flushed the ABS pump. Considering how much fluid that took I don't see how I could have any air in the ABS or front calipers.
Vacuum bled the rear calipers in place, with the bottom bolt out and tipped forward and finally removed from the axle and held so that there was no high spot in the flex line. I skipped the front because I'm assuming they must be fine after all the ABS flushing.
Bled the clutch.
Pressurized the master cylinder and cracked the two lines one at a time. I wouldn't know if air came out but plenty of fluid did.
Not run the master cylinder reservoir dry or low.
None of this has made any difference in the pedal with the engine on but it might have made it very slightly firmer with engine off. Too subjective to say for sure.
Backstory:
The car has been off the road and in the driveway for about two years. I worked a 3 minute walk from home and I have access to another car, but now I need to get this one back on the road. It was parked because I have to do a heater core and had enough else going on that I never got around to a PITA low priority job. I THINK that the last thing I did around the time the car was parked was replace arear caliper and the e-brake cables because one was seized up due to a break in the sheath.
2. What I've tried
So far I have:
Bled the clutch.
Backstory:
