Hi there,
I am aware that the stock lug bolts on these cars is 27mm in length. I'm looking to replace them with conical seat, longer bolts for aftermarket wheels, but I need to know something first before ordering the new lug bolts.
What is the longest length of lug bolt that I can fit on my wheels (with no spacers) before making contact with other objects behind the hub, such as the ABS ring, sensors, etc?
Reason I ask is because I may use 5mm spacers with my new wheels, or I may not. ECS has a wide selection of bolts, but the specific size I need are not in stock at the moment (35mm, playing it safe, but can't wait 10 business days for them to restock) and I need these bolts by next week at the latest! I was going to order 38mm bolts instead. These bolts will definitely work with 5mm spacers in place without issue, but just in case I went to another wheel that didn't require a spacer, I don't want to have to order a whole new set of bolts. Would these 38mm bolts cause any interferences behind the hub, even if I decided to run without a spacer?
