Stock intercooler replacement
2003_unicorns
Virginia
2003 Jetta Wagon manual & 2003 Golf 2dr. manual
My guru has graciously informed me that the my stock Golf's intercooler has a hole in it from rubbing over the years.
I might be with epoxying if it is salvageable (I don't know exactly where it is) but wanted to get your thoughts on replacement that fits with no hassles.
I am on a set budget for this car and want to know where you got your replacement if replacement is required here.
Thanks.
burpod
teh stallionz!!1
cape cod, ma
this is a good one, it's fin-tube on the inside like a real intercooler. not all ebay intercoolers are that way:
its 2.25" inlet/outlet. fits perfect if you upgrade to a 1.8t metal pancake pipe
to fit with stock you would have to use a couple 2.0" to 2.25" silicone coupler reducers
i think fcpeuro has a stock intercooler for $100, iirc by behr
many times the stock itercoolers leak from the plastic shroud rubber holes in the tubes. either that or the plastic end tanks have sprung a leak at the crimps
2003_unicorns
Virginia
Thanks!
454k30
Long Beach, CA
2002 Jetta
This is the one I have. Needed to trim the inside of the bumper cover a bit to make it fit without rubbing, but nothing too drastic.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Thanks.
It's underneath, if possible patch it with epoxy after getting it nice and clean.
Nuje
Island near Vancouver
Are the mounting tabs in the right place on this one?
Way back when I got one of these (or at least the "tacotaco" one looked the same), the tabs were slightly out and had to be "adapted" with some spacers or something in addition to trimming out some plastic on the inner side of the bumper cover.
burpod
teh stallionz!!1
cape cod, ma
i think they can be all slightly different. but it will fit with some futzing, might need to bend a couple slightly, or maybe mount it ontop, or inbetween those 2 top mount points, and then also tweak the lower bracket if you need to angle it up a bit more to get clearance on the frame.
454k30
Long Beach, CA
2002 Jetta
They were close enough that some light bending got them to where they needed to be. I also drilled out the mounting holes to accommodate the stock rubber mounting bushings. Also, the MAP port is not in the same location as the stock unit so you will need to route the wiring to that sensor a little differently. It's not really an issue, but just be aware so that you don't add a ton of pre-load to the wiring harness.
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
Most/all all-aluminum aftermarket IC's are a bit thicker than stock, so the stock piping from the turbo outlet to the IC will need to be shortened. On my car, that has resulted in not being able to attach the pancake pipe to the frame of the car, because now the pancake mounting hole is aft of the stud about half an inch. So far, it seems to be doing OK with only the hose clamps holding it in place; and I'm sure I could find a way to mount it if I wanted to get creative in fabrication. But just FYI FWIW.
