I'm not sure I follow that logic. A turbo, any turbo, for all practical purposes, should have no problem filling up a larger intercooler and related piping, when upgrading. The volume ingested by the engine is unchanged. The only difference is the volume of the IC and piping. Unless the IC and piping is impractically large, the turbo will compress this new volume to the manifold pressure called for by the wastegate/vnt nozzle. There may be a lag, as the turbo works to compress the air, but it will. I understand that simply cooling the air will also make it denser and now require even more air, but ultimately it should catch up. Unless the turbo is really small, and the IC really large. The lag maybe undesirable, and then a larger turbo may be warranted. I can't see how a vnt17 was down on boost simply by upgrading the IC/piping, unless the turbo was already severely maxed out to begin with. Even then, the reduction in boost was simply not giving the turbo enough time to catch up. If I'm wrong, somebody educate me please.
RT
